tps light is blinking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Aug 15, 2010.
  1. Aug 15, 2010 at 9:14 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    after i installed my x runner rims on my 2006 tacoma standard cab it was running ok until a week later when my tps light is blinking. What could be problem??? it was ok for a week until today this happened it blinking all the time??? tire pressure is all good any advice???
  2. Aug 15, 2010 at 9:20 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    reprogram the TPS.
  3. Aug 15, 2010 at 9:21 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    did you reinstall your original TPMS sensors into the X rims?
  4. Aug 15, 2010 at 9:41 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    did you check the pressure in the spare?
  5. Aug 15, 2010 at 9:45 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    X2
  6. Aug 15, 2010 at 10:03 PM
    pinktaco808
    no man they came with the x runner rims why???
  7. Aug 15, 2010 at 10:06 PM
    rdcar
    rdcar Well-Known Member
    07 tacoma
    X2
  8. Aug 15, 2010 at 10:06 PM
    jhodge83
    SC
    17 XLT Sport
    b/c they need to be programmed to your computer. they do not pick up random TPMS on their own. dealer will charge like $90 to do this.
    oh...and if you still have your stockers around, the computer will pick them up and you will have no light while near them, but once you get away from them the light will go off.
  9. Aug 15, 2010 at 10:26 PM
    pinktaco808
    the only stocker is in the spare if it has one does it??? can you re program it yourself???? finally where the write on cutting the wire to the tps system???
  10. Aug 15, 2010 at 10:30 PM
    jhodge83
    SC
    17 XLT Sport
    if you have an 05-08, then you have one in the stock spare. you cannot reprogram it yourself. and i'm not sure about cutting the TMPS system.
  11. Aug 15, 2010 at 10:58 PM
    pinktaco808
    so just let it blink????
  12. Aug 15, 2010 at 11:01 PM
    jhodge83
    SC
    17 XLT Sport
    it's not hurting anything. mine has been blinking for over 40k miles now. i have a set of TPMS installed in my rims, but never cared to have the dealer reprogram it. either let it blink, have them reprogram it, pop out the cluster and remove/cover the LED, or find out how to disable the system itself
  13. Aug 15, 2010 at 11:02 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Fabtech Lift on top of 3 inch body lift. 34s trail grapplers on 18inch eagle alloys. KRFab Rear bumper, BHLM with HIDs, TRD seat covers, Hood scoop, N fab tire carrier, black valence, TRD intake, 40s Flowmasters, Foglight mod, best for last and thats my 4.56 gears, and much more too come.
    I know if you cut it it will just blink forever and youll regret cutting it. Have you aired up your spare? I know mine keeps going off now because I dont have a spare under there nomore. When i put new rims on and the tps it didnt change anything. So Its either the spare or those new tps on the truck. Just dont cut anything!
  14. Aug 15, 2010 at 11:14 PM
    pinktaco808
  15. Aug 16, 2010 at 9:35 AM
    Silver06Taco
    Silver06Taco Well-Known Member
    WA state
    Silver 06 DC TRD Sport
    Some tire shops can do the reprogramming. Otherwise electric tape can do the job.
  16. Aug 16, 2010 at 7:17 PM
    OffroadToy
    4X4 Offroad
    Or you can remove all the sensors...there's a strap available that fits like a large hose clamp to secure the sensors to the insde of each wheel. Also, you could do the pipe bomb... Get some pvc pipe and cap one end. Drill and install a valve stem in the cap. Put sensors inside, cap the other end and fill er up to around 32 psi. Strap this thing to the frame or inside a storage compartment. Another method is to get a wheel barrel tire, remove the tire from the rim, throw in the sensors, re-install tire and fill up to 32 psi.
  17. Aug 16, 2010 at 7:22 PM
    jhodge83
    SC
    17 XLT Sport
    it would still have to be reprogrammed as the sensors in his wheels are not the stock ones that the computer is looking for
  18. Aug 16, 2010 at 7:23 PM
    MsTRD
    MsTRD hell yes i love my truck
    Samantha
    Rohnert Park, CA
    06 White Prerunner TRD Sport
    mines been blinking since january...you get used to it :)
  19. Aug 16, 2010 at 7:24 PM
    jhodge83
    SC
    17 XLT Sport
    mine's been blinking since the day i bought it and swapped off rims/tires from my 07...over 2 years ago..haha
  20. Aug 16, 2010 at 7:32 PM
    OffroadToy
    4X4 Offroad
    forgot about that...would he have to get the serial#'s off each sensor for a re-program?:confused:
