TPS location on 1998?
Discussion in '4 Cylinder' started by AWilliams, Mar 20, 2010.
  1. Mar 20, 2010 at 1:16 PM
    AWilliams
    AWilliams [OP] New Member
    Doing some reaserch I've came to the conclusion my TPS is what's causing my hesitation issues. Can someone tell me where I would find this and is it easy to replace?
    1998 4 cyl. 2.4l Tacoma
  2. Mar 20, 2010 at 4:12 PM
    Wrencher86
    Wrencher86 Active Member
    Chicago, Il
    '10 4x4 5Spd Reg. Cab 4cyl.
    It's on the throttle body. On the other side of where the linkage is.
    Not to be an ass or anything... But if you don't know where it is how did you diagnose it as being bad?
  3. Mar 20, 2010 at 5:58 PM
    AWilliams
    because I've been chasing this issue for close to a year now and my mechanic is useless. I've been doing an internet search for similair symptoms.
    BTW,,,what difference does it make if I'm trying to chase this issue down myself and not knowing where it is? I don't see the connection. I plan on testing it first...
  4. Mar 21, 2010 at 8:55 AM
    Wrencher86
    Chicago, Il
    If you're planning on testing it first than that's fine. It just sounded like you were ready to replace it based on some research without actually looking at it.
    Did you try a different mechanic? TPS sensors aren't that hard to diagnose ase being bad.
