TPS numbers off?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CZ-Jack, Jul 3, 2019.
  1. Jul 3, 2019 at 12:13 PM
    CZ-Jack
    CZ-Jack [OP] Well-Known Member
    2019 DCSB OR Cement
    My TPS numbers seem to be off, and I'm wondering if this is normal?
    I checked my tire pressure with 2 gauges and they read 31 PSI. TPS seems to think my tires are at 25-26 PSI...
  2. Jul 3, 2019 at 12:21 PM
    phatfisher
    phatfisher Member
    2018 Cement Tacoma TRD Off-Road
    I'm sure it's normal. Mine tend to hover about 4-5 psi lower than what's shown when i test them with a gauge.
  3. Jul 3, 2019 at 12:31 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    I always use a known quality gauge every fill up and there’s is definitely a difference between the TPMS and the gauge. I’ve tested my gauge against two others and they are consistent so I know the TPMS is a little off.
    I just consider the TPMS as my “hey, you got a tire going down”. It will yell at you when it notices a wide difference between the tires and will tell you which ones got a nail, screw, or whatever
    Boghog1 likes this.
  4. Jul 3, 2019 at 12:45 PM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    Yeah... I'll 2nd what everyone else has said: my tire pressure sensors are always lower than all of my pressure gauges. Must be the design...
  5. Jul 3, 2019 at 12:48 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Yup, almost all 3rds gens read wrong from a gauge
  6. Jul 3, 2019 at 12:54 PM
    Chad_QS18
    Chad_QS18 Well-Known Member
    Chad
    NoVA
    2018 Quicksand Tacoma Offroad
    Slammed on 16s
    TPMS*
    My TPMS displays accurate numbers. Whats displayed on my cluster always is within 1 psi of an actual gauge on the tire.
  7. Jul 3, 2019 at 1:01 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    I use a digital guage, and my TPMS reads just 1 PSI off, cold. Guage says 35, TPMS says 34.
    All 4 are the same.
    G.
    Rick111 and Tullie D like this.
  8. Jul 3, 2019 at 1:03 PM
    john221us
    john221us Well-Known Member
    Rocklin, CA (Sacramento)
    2019 Toyota Tacoma Limited
    Bed Mat
    My TPMS seems to be about 4 lbs low on every tire, against my gauge.
  9. Jul 3, 2019 at 10:42 PM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    The TPMS sensors are calibrated for a certain elevation, sea level possibly. So the higher the elevation, the farther off the sensors will be from the real gage pressure.
  10. Jul 3, 2019 at 11:11 PM
    Drifter001
    Drifter001 Well-Known Member
    Mine seem to be accurate (within 1 lb). I'm at approx 50 feet elevation above sea level.
    Rick111 and Vbpiper like this.
  11. Jul 4, 2019 at 6:00 AM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Off topic a little, on my 16 when I swapped my in the winter summer change the steelies with tpms to my rims w/o parked in the garage by tires. I could drive 10 miles to work and back and it would never show low tires pressure unless it was 30 miles + 1 way at highway speeds park in garage next morning off. This was on a SR. The only time it worked correctly was I picked up a nail in the winter. My SR doesn't read actual pressure per wheel just if in range set.
  12. Jul 4, 2019 at 6:10 AM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    One of my all time favorite movies. I too have had a lifelong dream of doing nothing...
    helix66 and Vbpiper like this.
  13. Jul 4, 2019 at 7:49 AM
    john221us
    Bed Mat
    I am at 50 ft above sea level and mine read about 4 lbs low. Just a data point. I guess I can go buy another gauge and check that.
  14. Jul 4, 2019 at 8:01 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I doubt TMPS is going to be as accurate as a good quality gauge measured at the tire stem, but should be within one, at most two lbs. Mine are usually right on. I think the altitude theory may affect this but when you think about it, it should equally affect either measurement system. Unless being inside the tire reacts differently to atmospheric pressure than a gauge at the tip of the valve stem outside the tire.. Donno :notsure:
  15. Jun 9, 2020 at 9:12 PM
    Rick111
    Rick111 Well-Known Member
    Rick
    2019 DCSB TRD OR 6M
    ARE Z series cap w/Bedrug
    Mine is within 1 psi of the handheld gauge as well. Using a 6 year old JACO 0-60 psi elite.
  16. Jun 9, 2020 at 10:24 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    The shop air compressor says 40 psi, my cheap oreillys tire pressure gauge says 40 psi, my cheap portable tire inflator from oreillys says 55 psi but it does it’s job very well. I do the “look at each tire before a long trip” before a drive since it does not display it on the little screen.
  17. Jun 10, 2020 at 1:35 AM
    Avail211
    Avail211 Well-Known Member
    2016 BBP TRD OR
    Mine is always accurate within 1lb and I'm almost at sea level.
  18. Jun 10, 2020 at 1:53 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Likewise.
