Tps quit reading tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lucky413, May 9, 2018.
  1. May 9, 2018 at 7:01 PM
    Lucky413
    Lucky413 [OP] Member
    2016 Tacoma trd 4x4 quad cab
    I had a tire low and aired it up and now it quit reading them all. I reset the system but it still doesn't read. Do I need to drive it? It's a trd off road with multi information display
  2. May 9, 2018 at 7:07 PM
    cruetes
    cruetes DYWAI
    El Paso, Texas
    2016 QuickSand Taco SR5
    I had this happen when I had a tire replaced. If one goes bad; all of them stop working. It’s probably that one is defective.
  3. May 9, 2018 at 7:10 PM
    cruetes
    cruetes DYWAI
    El Paso, Texas
    I’ll add: I went back to the place who did my tire. They replaced my one sensor and they all started working again. Get the sensor looked at or possibly change it yourself and it should be good to go.
    Unless someone has a better option.
  4. May 9, 2018 at 7:11 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Drive it around a bit. See what happens.
    over60 and shakerhood like this.
  5. May 9, 2018 at 11:29 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    This, last time I rotated the tires it took about 10 miles or so before it started to show pressure on the display again.
    Oldman808 likes this.
  6. May 9, 2018 at 11:41 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Hey did you read your owners manual?
  7. May 10, 2018 at 4:04 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    You have to drive it a little bit for it to start reading the pressure, it doesn't register if the truck isn't in motion.
    Unusual yes but that's the way it works, I also carry a tire gauge to check when airing up and compare once in motion.
