TPS RESET?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hotrod45, Jun 23, 2018.
  1. Jun 23, 2018 at 10:11 AM
    hotrod45
    hotrod45 [OP] Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    my '16 sr 5 came with steelies and i opted to buy alloys taken off of a new vehicle, without tpm's. i sold the other wheels, tires with the tpm's because they were easier to sell. so i bought after market tpm's specifically for the tacoma and had them programmed. working fine. at the 25k service, tires were switched. the pressures were changed to 35 front 33 rear. deal is, the dash tpm values are showing the opposite, 33 front, 35 rear. so, i guess they don't reset themselves. any tricks?
  2. Jun 23, 2018 at 10:21 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    My 2013 has the directions in the owners manual. I think anytime the sensors are replaced, the computer needs to be reprogrammed, when the wheels are rotated, the reset directions in the manual will work. Give it a try & let us know.
  3. Jun 23, 2018 at 11:22 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Set to the pressures you want and then press the reset button
    over60 likes this.
  4. Jun 25, 2018 at 5:14 AM
    hotrod45
    paul
    sarasota fl
    16 sr 5 access cab
    did just that and it worked fine. thanks for the info!
    shakerhood likes this.
