TPS sensor question.
Discussion in 'Wheels & Tires' started by Gasitman, Apr 29, 2012.
  1. Apr 29, 2012 at 10:35 PM
    Gasitman
    Gasitman [OP] Member
    Gig Harbor, WA
    OK, so I just traded in 2 vehicles for my new Tacoma, one of which was a scion Xb. I have some aftermarket wheels and tires that were on it. I am going to buy a 3" lift and get an additional set of wheels and tires. Anyone know if the TPS sensors from the scion will work on the Tacoma? Does Toyota use all the same sensors?
  2. Apr 30, 2012 at 3:13 AM
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    They should be programmable....but I do not know if they will fit.
  3. Apr 30, 2012 at 5:24 AM
    DevL
    DevL Well-Known Member
    Not 100% sure but thought only one set of tpms sensors could be memorised by your truck at a time. Which means you are better off swapping in your current Tacoma sensors to custom wheels
    . That is what I did. My factory wheels/ tires just have rubber valve stems.
  4. Apr 30, 2012 at 5:55 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    x2
    Only 5 spots in the TPMS ECU for sensor codes. (Toyota use to put them in the spare).
  5. Apr 30, 2012 at 7:53 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    If you're concerned about fit you could always band them to the inside of the rim. Weather or not you can program them is a different story.
