TRAC and TRAC OFF with Yellow Wire Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by off road, May 27, 2015.
  1. Nov 27, 2015 at 4:30 AM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    I ran my yellow wire mod on a switch. When going L4, everything engage like if there is no mod and then I shut off the yellow wire. No beep, no Lo blinking and the trac light (yellow car spinning) disapear from the dash. By shutting off the yellow wire after engaging in L4, does my truck "knows" that it's in L4 or does I fool it and "think" it's back in H4?
  2. Nov 27, 2015 at 5:53 AM
    off road
    off road [OP] Well-Known Member
    So Calif
    2015 Double Cab TRD OR 4X4 & 2013 Reg Cab Base 4X4
    I thought that all this started with the 2009 models, but may be mistaken. Searching "yellow wire mod", you might come up with better info.
  3. Nov 27, 2015 at 7:43 AM
    Laurence243
    Laurence243 Active Member
    2010 Tacoma 2.7, 5-speed, 4wd
    Yellow wire mod, LCE header, 2.5" cat-back exhaust
    Yep
  4. Nov 27, 2015 at 9:48 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Hmmm....I'm not sure. Have you tested to see that the TRAC is working in 4L?
  5. Nov 27, 2015 at 10:12 AM
    Laurence243
    It seems to but it has been a while since I've had the truck stuck.
    In 4hi a short press on the VSC button doesn't light up the TRAC off indicator either.
  6. Nov 27, 2015 at 12:29 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    In 4H a quick push of the VSC button illuminates TRAC OFF. The same thing happens in 4L. Maybe the bulb that lights up that indicator isn't working.:notsure:
  7. Dec 3, 2020 at 9:50 AM
    TacoRAhma
    TacoRAhma Active Member
    Denver Colorado
    2010 Pyrite Micha Tacoma DC SR5
    Ome 884, ome 90021, ome 60021, ome leaf pack, spc uca’s, Leer cap, bf k02s, carplay head unit, carhartt seat covers, 15% tinted windows, bed extender, power outlet in truck bed, spare tire lock
    Reviving this from the dead because I am about to do the enhanced YWM on my 2010 4x4 DC SR5...2010 base, SR5, and sport models do not have a TRAC OFF light in the dash cluster... the reason is in 09-11 the normal mode for 4H is TRAC with no engine regulation, which is equivalent to TRAC OFF in 2012-2015 models. 09-11 has no quick press option in 4H, just long press to when stopped to open the diffs.
