Trac Off and Cruise Control and S-Mode Not Working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by facefirst, Feb 6, 2020.
  1. Feb 6, 2020 at 12:33 PM
    facefirst
    facefirst [OP] Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    So for the past month I've had some intermittent issues and I'm not sure if they're related or not.
    First, randomly the "Trac Off" light comes on along with the check engine light. When this happens I can no longer use cruise control. Then (sometimes in conjunction with the Trac Off issue and sometimes separately from it) I'll shift to drive but there's no "D" on display on the dash. If I switch to S-Mode it will flash 4th gear for a second and then go blank. If I put it back in drive the D flashes for a second and goes blank. Again, I can't use cruise control when this happens.
    Anyone else ever had this problem or know what might be the culprit? Thanks.
    Fishnwiz likes this.
  2. Feb 6, 2020 at 12:39 PM
    facefirst
    Geoff
    Cleveland, OH
    I should also note that the rear sensors went bad so my cross traffic alert and blind spot monitoring were not working. Even out of warranty Toyota replaced them, which is great. I'm actually going to pick it up in a bit because of that. Maybe the sensors were causing that issue as well?
  3. Feb 6, 2020 at 3:21 PM
    facefirst
    Geoff
    Cleveland, OH
  4. Feb 6, 2020 at 4:09 PM
    BigHam
    BigHam dɹǝp
    Does the CEL stay on for an extended period when it comes on? If so, have you ever pulled the codes to see what comes up?
  5. Feb 6, 2020 at 4:16 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Inspect your wheel speed sensors
    facefirst[OP] likes this.
  6. Feb 7, 2020 at 8:15 AM
    facefirst
    Geoff
    Cleveland, OH
    Yeah, it'll stay on for days but no codes are thrown. The dealership guy said it's probably because of the faulty sensors that they replaced. I guess I'll just see what happens. Hopefully that is the culprit.
  7. Feb 7, 2020 at 8:16 AM
    facefirst
    Geoff
    Cleveland, OH
    Noted. If it does it again I'll mention that to the service guy.
