Trac Off and engine light came on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beaner42082, May 7, 2021.
  1. May 7, 2021 at 2:36 PM
    Beaner42082
    Beaner42082 [OP] New Member
    Christian
    2015 Toyota Tacoma access cab 2.7L
    None
    I have a 2015 Toyota Tacoma 2.7L and just installed afe cold air intake and my TracOff and check engine light came on.....this isn't normal is it?
  2. May 7, 2021 at 2:40 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    You have an air leak at the map sensor and your stock air intake was a CAI. Take that crap off and go back to stock, clear the code and you will be good. Good luck with your truck.
    6 gearT444E likes this.
  3. May 7, 2021 at 2:47 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Make sure mass air flow is connected tight
    Beaner42082[OP] and Mully like this.
  4. May 7, 2021 at 2:49 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    The only issues I had with my K&N cold air intake was I had to reset my idle I was at 1500, after reset back down to 750-800
  5. May 7, 2021 at 2:52 PM
    Beaner42082
    Christian
    None
    Lmao fixed, thanks!
  6. May 7, 2021 at 8:29 PM
    EME
    EME Well-Known Member
    Nick
    05 Tacoma sport
    usually engine codes will trip trac light/abs on most vehs. fault codes in ecm will trigger the other computers to switch off stability or traction controls, some kind of built in safety feature I guess
