Trac Off, Check Engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by W8N41, Nov 10, 2017.
  1. Nov 10, 2017 at 8:04 AM
    W8N41
    W8N41 [OP] Active Member
    2017 DCLBOR QS
    They say it's bad gas.....we shall see.
    I do not know the exact codes but was showing vacuum leak and lean on 2 cylinders.
  2. Nov 10, 2017 at 12:47 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    CKP is my guess. Is it ever really bad gas?
    shakerhood likes this.
  3. Nov 10, 2017 at 2:06 PM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    02 sensor reading bad most of the time. As simple as the gas cap loose sometimes. My 4Runner had that the whole 4 years I had it and it was either bad O2 or CAT.
  4. Nov 10, 2017 at 2:08 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Bad gas shouldn't show those codes...
  5. Nov 10, 2017 at 6:33 PM
    W8N41
    2017 DCLBOR QS
    Well, I filled up the day it happened(Wednesday). They came on about 15 miles after fill up. I tried to reset it myself (battery disconnect) but it came back(Thursday morning). By the time I got by the dealer I was at 1/4 tank(Today, Friday).
    So I left the dealer and bought a can of SeaFoam(lights were reset at dealer), I am now one can of seafoam and 2 full tanks of gas later and they have not returned.
    Also, my MPG had dropped from my normal 18mpg to 16mpg. By all indications, it was just bad gas. Unless it comes on tomorrow.
    PS: Yes I filled up full twice today, I drove a long way.
  6. Nov 10, 2017 at 6:43 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    I'm always careful where I buy gas, but I guess even quality stations could have their issues.
  7. Nov 10, 2017 at 6:48 PM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    I found out the hard way that it does not take much of a leaky gas cap to set these error codes. For 5 months I had a locking gas cap--no problems. then all of a sudden late this summer those codes popped up. Dealer said that cap was it --of course I did not believe them as I had ran with the locking cap for 4-5 months. I put the OEM cap on the prob stayed away for 2 tanks. Tried the other cap again --prob came back --this time I had a mechanic friend reset it back. I did not want to "eat crow and go back to the dealer.
    Make sure you are getting your cap tight --or maybe you have a bad cap?
    NM Lance likes this.
  8. Nov 11, 2017 at 5:48 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Ha, we probably had the same gas cap! And it was advertised as NO CELs and it too worked fine for a couple of months but after I left my truck in an outdoor parking structure in the late summer for a couple of days, I hopped in and my dash was Christmas lights! Changed back to OEM and cleared the codes with OBD Fusion, but the “permanent” codes hung around for a few weeks until enough drive cycles completed for it to clear them.
  9. Nov 11, 2017 at 5:53 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Bad gas? The dealer saw these codes and said bad gas. Lmao
  10. Nov 11, 2017 at 7:09 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Even the Toyota techstream can't clear the permanent codes because they are "permanent"
  11. Nov 11, 2017 at 7:24 AM
    NM Lance
    NM Lance Well-Known Member
    These locking gas caps are hit-and-miss. I have tried two brands, one of which I was told was junk, but it turns out that was the only one that sealed and did not give me the check engine light. Standt brand is what I am using.
  12. Nov 11, 2017 at 7:49 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    You took a picture at nearly 80 MPH ??? WTF Dude???
    G.
    W8N41[OP] likes this.
  13. Nov 11, 2017 at 10:18 AM
    bshammer0
    Brandon
    Nashville, TN
    right, but so long as the concern has been corrected it will clear itself after a lot of driving cycles. I probably had 100 warm ups before mine cleared from that damn gas cap that's about to go in the recycling bin...
  14. Nov 11, 2017 at 10:26 AM
    W8N41
    2017 DCLBOR QS
    No, First he thought gas cap, then they thought fuel pump or injector issue. Everything checked out. After 2 hours. Bad gas.
    The speed limit is 75, I'm not going that fast.... ;-)
    2 lane road, no one around. Yeah, I took a picture while driving. I have had my truck 9 weeks. If I waited to stop I never would have taken it. I'm at 11K miles today.
  15. Nov 11, 2017 at 3:17 PM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    I've only ever experienced two things with bad gas:
    1) paranoids being careful where they buy gas
    2) toyota dealerships failing to diagnose problems
    xufer and JayRolla like this.
