TRAC OFF LIGHT
Discussion in '4 Cylinder' started by dirtfan, Aug 29, 2012.
  1. Aug 29, 2012 at 10:45 AM
    dirtfan
    dirtfan [OP] Member
    South Carolina
    2012 PreRunner SR5
    I GOT IN MY 2012 TACOMA THIS MORNING, FIRED HER UP, AND CHECK ENGINE LIGHT AND TRAC OFF LIGHT STAYED ON. I HOOKED UP MY DIAGNOSTIC CHECKER AND IT SAID EMISSIONS CONTROL SOMETHING HAD A SMALL LEAK. SO HEADED BACK TO THE DEALERSHIP TODAY OR TOMORROW. JUST CAME FROM THERE FRIDAY FOR 10K SERVICE. MY QUESTION IS WOULD ANYONE MIGHT KNOW WHAT IS KEEPING THE TRAC OFF LIGHT ON? AND WILL IT HURT TO CONTINUE TO DRIVE IT IF I CAN'T GET TO DEALERSHIP UNTIL TOMORROW? THANKS IN ADVANCE FOR YOUR HELP AND FEEDBACK.
  2. Aug 31, 2012 at 7:18 PM
    RACINGMEMO
    RACINGMEMO Active Member
    GUILLERMO
    San Diego
    2012 AC 2.7 SR5
    NONE
    did u find out what it was?
  3. Sep 3, 2012 at 12:36 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    There is a key on your keyboard that makes the caps lock light go off.
  4. Sep 3, 2012 at 12:38 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    VSC/TRAC light is common to have with a CEL.
    It simply indicated that the traction control is disabled.
    It'll shut off when the dealer fixes the problem and clears the CEL.
  5. Sep 3, 2012 at 2:58 AM
    dirtfan
    dirtfan [OP] Member
    South Carolina
    2012 PreRunner SR5
    Cool.....thanks alot for the help and the info Rich91710....and sorry 4wheelin4banger for making you have to read something in all caps.
  6. Nov 26, 2012 at 6:19 PM
    MotorsportsAustin
    MotorsportsAustin Well-Known Member
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Mine (2012 DC OR) did this last week, started it and CEL + TRAC light on. Back to the dealer (again), was told fault #P0456, Evaporative emission control system leak, faulty gas cap. Dealer replaced cap, light's been off for over a week now. Looks like it's remedied.
    PS I still hate Toyota for manufacturing my Tacoma with acceleration shuddering and faulty clutch pressure plate (doesn't allow clutch, engine, and trans to fully disengage and allow gear change) which Toyota says are "characteristic" of the vehicle and refuses to remedy.
  7. Nov 26, 2012 at 6:31 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    It would've been worthwhile to post an accurate fault message. :rolleyes: Probably the same gas cap fault MotorsportsAustin posted. You can sometimes clear it by just removing and re-tightening the gas cap. Give it three good clicks.
    Is this the RPM hang typical with Taco 6-speeds?
  8. Nov 27, 2012 at 11:47 AM
    MotorsportsAustin
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Toyota told me it's normal, although I think it's a little odd that when you let off the gas it continues (for about 2 seconds) to deliver the same fuel as when you had your foot in it, even though you've let off completely. If you put in the clutch it'll actually rev about 200 rpm's higher.
    I've never driven any other vehicle with this 'feature', but have driven some with very heavy fly wheels (i.e. newer BMW 3 and 5 series) that like to hold the rpms with inertia.
  9. Nov 27, 2012 at 2:11 PM
    KenLyns
    Belly of the Beast
    ^The RPM hang is a "normal" characteristic in the sense that every Taco 6-speed since 2005 does it. The FJ Cruiser's 6-speed does the same thing. Toyota hasn't fixed it for 7 years, and probably won't budge until the next-gen Taco comes out in ~2 years. (At which point the manual transmission might disappear... along with regular cab models. :() Wonder why Toyota built the RPM hang into the ECM logic.
  10. Nov 29, 2012 at 11:07 PM
    MotorsportsAustin
    Austin
    Belmont, CA
    2012 Off Road 6spd
    If I keep this truck, which I probably won't since it's been a $32,000 pile of crap in so many ways (driveline shake, faulty clutch system, steering column knock, weak suspension, rattles...lots of rattles), I'll get the rpm hang programed out and report back on the effects.
  11. Apr 21, 2013 at 9:51 AM
    Larry wall
    Larry wall Member
    Larry
    Paradise, nl
    2013 limited Tacoma
    Just got a new truck. Have 1348 Km's on it. The trac off light ,came on and engine light also came on and both stayed on. Shut unit off but both never went away The next thing that happened was that it started stalling on me It would start fine and run ok in park but once I placed it in drive it stalled. Some time right away other time it may be 15 Km's down the road. Waiting on dealer to test truck. Got towed to dealer ship on Friday evening. Having to wait till Monday to see what it is. They tried to tell me that I placed diesel in it. Any idea what the issue would be
  12. Apr 21, 2013 at 9:58 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Trac on and engine light on are normal for when the truck throws a code
    I had the same thing happen on my truck , turned out to be something as simple as a loose gas cap that was throwing the code
    Not sure what is causing your stalling issue though
  13. Jul 31, 2013 at 5:26 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    My 2012 Tacoma with 17,000mi did the same thing this morning on my way to work. Both Engine and TRAC warning lights popped on. At lunch time I'll go out to check my fuel cap. I did fill it up last time I drove it a few days ago. Maybe the 1 "click" tighening didn't seal?
    I'll see if this clears up issue before I call Dealership.
  14. Jul 31, 2013 at 7:22 AM
    OZ-T
    Peter North
    British Columbia
    3 clicks and you will have to get the code cleared
  15. Jul 31, 2013 at 3:39 PM
    wags
    Nope. Turned 3 clicks (usually just one as on cap instructions) and didn't reset anything. Will call dealer tomorrow and raise a little heck. 2nd time in 6 months check engine light has come on (1st time TRAC OFF). All they've done is reset and said all is good/normal. My time and gas driving there for a 5 minute job.
    I bought this vehicle because they were bulletproof I was told?
  16. Jul 31, 2013 at 3:52 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    Just retighten the gas cap and take it to a autumotive store... they'll clear the code for free.
  17. Jul 31, 2013 at 4:02 PM
    OZ-T
    Peter North
    British Columbia
    I said you would need to get the code cleared . You no read so well ?
  18. Aug 5, 2013 at 12:01 PM
    Larry wall
    Larry wall Member
    Larry
    Paradise, nl
    2013 limited Tacoma
    yes-- i filled up at a gas station and the pump truck was either filling up the main tanks or had just left-- there was stuff in the main tank that was mixed with the regular gas that was being placed in there at the time-- i just happened to be unlucky enough to fill up at the time and transfer it into my tank. the gas company is fitting the bill for my issue-- no damage to the truck --
  19. Aug 6, 2013 at 7:11 AM
    wags
    Dropped my Tacoma off to dealership this morning. They called back and said reason Engine light and TRAC OFF light is on was due to a faulty Oxygen/Airfuel Sensor. And they won't have replacement part until tomorrow. Oh well. Said vehicle was fine to drive though in this condition. Hopefully this helps out anyone else with same problem.
  20. Aug 7, 2013 at 4:34 PM
    wags
    According to my dealership Service Department Invoice, it was 2 sensor's replaced, not just one. Oxygen Sensor & Air Fuel Sensor. I just want to be accurate for the readers.
