Trac off on the fly
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stoked4, Feb 11, 2017.
  1. Feb 11, 2017 at 1:28 PM
    Stoked4
    Stoked4 [OP] Well-Known Member
    2017 trd sport DCLB (OVtuned)
    anyone know of a way to turn the traction control completely off without having to be stopped while holding the button?
  2. Feb 11, 2017 at 1:44 PM
    su.b.rat
    su.b.rat broken truck
    cannot. dead stop, hold button for 3 secs to be completely off.
    shakerhood and sadmrhappy like this.
  3. Feb 11, 2017 at 1:54 PM
    Stoked4
    I looked for a fuse but there's none
    Kind of annoying
  4. Feb 11, 2017 at 6:31 PM
    Stoked4
    There's got to be
    Some
    Way
  5. Feb 11, 2017 at 7:33 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Send a letter to Toyotas lawyers to see if they will allow Toyota to allow them to make the changes.
    stealthmode likes this.
  6. Feb 11, 2017 at 7:34 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    ABS bypass switch
    Stig likes this.
  7. Feb 11, 2017 at 7:57 PM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    What's the logic behind this? Why would you want to disable it on the fly without having to stop?
  8. Feb 11, 2017 at 8:00 PM
    Stoked4
    I tested the abs bypass switch
    But it doesn't disable traction control
    The fuse labeled "abs 1" does abs and
    The fuse labeled "abs 2" is abs and brake booster
  9. Feb 11, 2017 at 8:01 PM
    Stoked4
    If your driving on a road that's snow covered the traction is a pita most of the time. Having to completely stop makes it even more of a pita
    EB Group, LEXICON and stealthmode like this.
  10. Feb 11, 2017 at 8:02 PM
    Stoked4
    If I do that I'd focus on the car shutting off while it's remotely started when the door is opened first. Total bs in my opinion
  11. Feb 11, 2017 at 8:06 PM
    Herniator
    Edmonton
    I'm sure that toyotas lawyers told them to do that. Otherwise some one might sue when their vehicle gets stolen. Too many sue happy people make it Shitty for the rest of us.
    A Salt Weapon likes this.
  12. Feb 11, 2017 at 8:08 PM
    Stoked4
    But wouldn't it make sense that the car would shut off only if the key isn't present when the door is open?
    I have a long thread about this on here somewhere
  13. Feb 11, 2017 at 8:09 PM
    Bishop84
    Bishop84 Well-Known Member
    Many smart key systems do this, it's standard fare. It has to switch from a security bypass to a proximity start.
    T4RFTMFW likes this.
  14. Feb 11, 2017 at 8:11 PM
    Herniator
    Edmonton
    Yes it would. I agree with you on the truck shutting off and stopping to take the traction control off. At least you don't have to press the "ok" button to clear the warning on the radio every time you start the vehicle. Some vehicles used to have that feature
    tonered and Stoked4[QUOTED][OP] like this.
  15. Feb 11, 2017 at 8:15 PM
    OZ-T
    Peter North
    British Columbia
    You did an ABS bypass switch mod ?
  16. Feb 11, 2017 at 8:22 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    GM let's you turn it off while driving. It would suck in winter if you didn't have that capability. As soon as my throttle gets cut trying to pull out on a road, off it goes.
    Stoked4[OP] likes this.
  17. Feb 11, 2017 at 8:27 PM
    Paterico
    San Antonio, TX
    Gotcha, never see snow down here so I couldn't see the use case. Makes sense now
    Stoked4[QUOTED][OP] likes this.
  18. Feb 11, 2017 at 8:30 PM
    Stoked4
    I tested it, what I mean by that is I pulled The fuse out under the hood that I will be running the wires from to the switch
  19. Feb 11, 2017 at 8:34 PM
    Stoked4
    My STI was the same way
  20. Feb 11, 2017 at 9:02 PM
    OZ-T
    Peter North
    British Columbia
    Huh weird , the ABS bypass mod on the 2nd gen kills the VSC / Traction Control too
    Stig likes this.
