Traccontrol or lsd in 4wd?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Matt777, Jan 9, 2020.
  1. Jan 9, 2020 at 11:05 AM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    I did read your comment. I was simply making note of the specific bit of information you may have been looking for. A video was also posted that may help.
  2. Jan 9, 2020 at 11:09 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    That video is a little misleading because it refers to all of the modes as “LSD”, but it is great otherwise.
    tonered likes this.
  3. Jan 9, 2020 at 11:10 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Meh, it's a video from a random dude on the internet, I was more interested in watching to see how the truck performed than what he had to say.
    tonered likes this.
  4. Jan 9, 2020 at 11:13 AM
    gudujarlson
    Minnesota
    I’m not sure which bit of information you are referring too. None of it explains to me my experimentally observed differences between TRAC and LSD. I know how VSC works and don’t see how it could be interfering with TRAC in these scenarios because the truck is sitting still with no yaw.
    BTW, I can’t stand VSC unless I’m driving in rush hour traffic on the freeway in icy conditions. I call it the “fun police mode”.
  5. Jan 9, 2020 at 11:18 AM
    gudujarlson
    Minnesota
    Fair enough.
  6. Jan 13, 2020 at 1:08 PM
    Jack_w00
    Jack_w00 Member
    1999 Toyota Tacoma 4x4 SR5
    Question. Which wheels get power in 4wd? I have a 99 Tacoma sr5 4x4. I can lock the diff but that’s not needed unless I’m really stuck. Just want to know which wheels to put my chains on. Mountain passes are requiring drivers to have chains regardless of 4wd or AWD. Never needed chains until drivers started getting reckless and making troopers enforce it now! Thanks for any replies.
  7. Jan 13, 2020 at 1:22 PM
    GreyBaldTaco
    2019 F150 5.0
    Rtfm
    tonered likes this.
  8. Jan 13, 2020 at 1:24 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :evil:
    :hattip:
    GreyBaldTaco[QUOTED] likes this.
  9. Jan 13, 2020 at 4:59 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I really think TRAC and AutoLSD are the same in their 'strength' despite some anecdotal evidence. They may not be the same on OR/Pro vs all the other trims (due to elec vs vacuum), but I believe they are the same on a given trim (from my bench testing).
    However note in 2wd vs 4hi the combinations of Trac and VSC are different
    2wd
    VSC ON, TRAC ON
    VSC OFF, TRAC ON (autolsd) - short press
    VSC OFF, TRAC OFF - long press
    4HI
    VSC ON, TRAC ON
    VSC ON, TRAC OFF - short press
    So notice in 2wd, you have an option for TRAC ON while VSC is OFF. In 4hi you dont get that as an option.
    Does this possibly explain some of what you are seeing?
  10. Jan 13, 2020 at 5:51 PM
    gudujarlson
    Minnesota
    No I don’t think so. It’s a common occurrence for me to be parallel parked on a street where 2 wheels are on dry pavement and 2 are on snow/ice. TRAC doesn’t seem to do anything in these situations, but pressing the LSD button does. I’m going to go out and experiment some more.
    GreyBaldTaco likes this.
  11. Jan 13, 2020 at 6:42 PM
    BigWhiteTRD
    Ted
    More data
    2hi or 4hi ?
    Short press or long press when stopped (of VSC button).
    What dash lights are on? Do you get the flashing squiggly ?
  12. Jan 13, 2020 at 11:43 PM
    Jack_w00
    Jack_w00 Member
    Haha.... should have clarified, truck didn’t come with a manual from previous owner. I’ll just go throw my truck around on the dirt and figure it out. Thanks anyways, Richard
  13. Jan 14, 2020 at 3:38 AM
    GreyBaldTaco
    2019 F150 5.0
    They are available online.
  14. Jan 14, 2020 at 9:18 AM
    gudujarlson
    Minnesota
    2wd of course. I wouldn’t be using the LSD mode otherwise. It’s a bit simpler to hit the LSD button in these situations because the majority of the road surface is dry pavement. There’s just ice/snow up against the curb. Short press to turn on LSD mode; not a long press to disable everything. I use the long press when I want to have fun.
    edit: my guess is that Auto LSD mode allows less difference in wheel rotation speed than TRAC. TRAC is intended for loss of traction at higher speeds whereas Auto LSD is for getting unstuck. It’s a bit confusing though, because I have experienced TRAC kicking in when accelerating from a stop light.
    I forgot to experiment with this last night when I was out messing around in the tiny bit of snow we got.
  15. Jan 14, 2020 at 9:24 AM
    #35
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    If you only have two I would put both on the rear.
  16. Jan 14, 2020 at 11:16 AM
    #36
    gudujarlson
    Minnesota
    I’m not sure I understand the question, because the answer seems too obvious. With the risk of telling you what you already know, 4wd means 4 wheel drive which means all 4 wheels receive torque (with some exceptions).
    Tripod1404 likes this.
  17. Jan 14, 2020 at 11:48 AM
    #37
    wolf2600
    wolf2600 Well-Known Member
    San Jose, CA
    2021 TRD-OR 6MT-SOLD
    Coyoza Tuned
    Is that for the "traction control" only, or also for the TRD-OR's "electronically locking rear differential"?
  18. Jan 14, 2020 at 12:02 PM
    #38
    ryan760
    ryan760 Well-Known Member
    Traction control is entirely separate from the electronic locking rear diff (apples and oranges)
    Traction control is software driven, actuating the brakes on any slipping wheels so that power is routed to the wheels that have traction.
    The rear diff lock mechanically locks the two rear axle shafts together using an actuator on the differential.
    MTS, Crawl Control, Traction Control, "Auto-LSD", "Trac"... all of these fall under traction control.
  19. Jan 14, 2020 at 12:04 PM
    #39
    wolf2600
    San Jose, CA
    Coyoza Tuned
    Just asking for clarification due to the previous comments about "these trucks don't have LSD, it's all brake-actuated 'traction control'"..... the exception is the TRD-OR which DOES have a locking rear diff.
  20. Jan 14, 2020 at 12:04 PM
    #40
    ryan760
    Correct. The ORs have both a locking rear diff and traction control.
