Traccontrol or lsd in 4wd?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Matt777, Jan 9, 2020.
  1. Feb 11, 2020 at 8:04 PM
    #61
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    This is a good test for everyone to try. I believe it was TRAC cutting your engine output as TRAC is known to utilize engine cut along with wheel braking to reduce power induced rear wheel slip. VSC should not have been active as the expected yaw rate would be zero since vehicle velocity was zero. VSC will definitely react to instances of zero yaw, but only if it EXPECTS yaw. In this case it should've expected zero yaw and sensed zero yaw.
    Remember, TRAC intervenes only to correct wheels that are getting engine power from slipping. VSC intervenes to keep the vehicle on its intended path. Auto LSD will not cut engine power while intervening to correct driven wheels slipping across the axle.
    Doggman likes this.
