Track light, check engine light, cruise control out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cutbow73, May 29, 2019.
  1. May 29, 2019 at 9:48 AM
    Cutbow73
    Cutbow73 [OP] Member
    2017 Toyota Tacoma TRD OFF-Road
    I know this thread has been put up before. Just a question. If the cause is the gas cap, how long until everything returns to normal after tightening gas cap?
  2. May 29, 2019 at 9:51 AM
    Cutbow73
    Also what other issues cause this other than a gas cap? I’ve been up in the mountains of Idaho for two months. Went from sea level to 6000 feet. Very dry and dusty up here
  3. May 29, 2019 at 10:13 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If you have a scan tool you can find out what codes or faults it has.
  4. May 29, 2019 at 10:28 AM
    Cutbow73
    I don’t. Im in a bit of a pinch. I’m literally in the mountains of idaho. Minimal tools. I tightened cap and disconnected the battery. I will have to drive a bit to see if it worked.
  5. May 29, 2019 at 10:29 AM
    Cutbow73
    I will pick one up when I get back home. For now I need to go off of help from others
  6. May 29, 2019 at 10:34 AM
    shakerhood
    Southern Ohio
    I doubt it is the gas cap, probably a bad sensor somewhere
  7. May 29, 2019 at 10:35 AM
    Cutbow73
    This new of a truck? Some garbage if it is
  8. May 29, 2019 at 10:39 AM
    shakerhood
    Southern Ohio
    Have you been wheeling in the mountains? Maybe you snagged an ABS wire or got something wet.
  9. May 29, 2019 at 10:44 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Unfortunately it could be lots of things, and we'd only be guessing,.
    Sorry, I know that's not what you want to hear.
    GL
  10. May 29, 2019 at 10:47 AM
    Cutbow73
    I hear you all. No heavy wheeling. Just light off-road and fly fishing. Nothing big.
  11. May 29, 2019 at 10:54 AM
    john221us
    john221us Well-Known Member
    Rocklin, CA (Sacramento)
    2019 Toyota Tacoma Limited
    Bed Mat
    My fiance lost her gas cap (more likely forgot it somewhere) on her VW Cabrio. Just the check engine light came on. My cheap ($12) ODB II Wifi gadget from Amazon pointed me right to it and as soon as I installed the new cap, the light went out. Not sure on the Tacoma, though. If you have Amazon Prime, you can get one delivered in a day or two.
  12. May 29, 2019 at 11:01 AM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    OP,
    I have had same issue with mine. Normally it will take about a full tank worth's of driving in order for the system to recalibrate (assuming the problem was due to not tightening the cap properly). It's a crap shoot, could be 2 days, could be a week... depends on your driving habits.
    I found my problem was due to a faulty charcoal canister. When you get a chance, have dealer do full diagnostics... don't let them tell you it's just gas cap issue... be weary.
    if you're stuck in the mountain, you just need to weather the storm for now. good luck.
  13. May 29, 2019 at 11:03 AM
    vuTron
    SF Bay Area
  14. May 29, 2019 at 11:03 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    If you tighten the gas cap, disconnect the battery for 1 min, then reconnect and start up, the light should clear. If it comes back, it was not the gas cap (unless it is defective). If you don't have any drive-ability issues, disregard the light for now.
  15. May 29, 2019 at 11:22 AM
    Cutbow73
    No I’m not stuck. Thank you though. I really don’t think it’s a sensor. I’ve been very kind to this truck. It’s always possible but I don’t think so. I wil get it checked when I get down the mountain
  16. May 29, 2019 at 11:35 AM
    Cutbow73
    Well tightened cap and disconnected battery for 3 minutes. All lights were off when reconnected. I’ve gone 12 miles and the lights have stayed off. Everything seems to be normal. Time will tell I guess. Thanks guys for the input. I will keep this thread updated with the end result of my trip
    shakerhood likes this.
