Tracking Down A Front End "Groan" Sound....???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crow Horse, Jun 19, 2024.
  1. Jun 19, 2024 at 5:15 AM
    Crow Horse
    Crow Horse [OP] Well-Known Member
    Central NY
    2012 DCSB TRDOR
    While moving at a slow speed, I can hear a subtle "goan" sound which oscillates with wheel movement.. It sounds like it's coming from the front end, maybe the driver's side.When applying the brakes the sound still persists. Any ideas as what this might be or where I should start looking?
  2. Jun 19, 2024 at 5:18 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Slide pins on your calipers?
  3. Jun 19, 2024 at 5:56 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    How would the slide pins create a "groan" sound?
  4. Jun 19, 2024 at 5:58 PM
    fatfurious2
    David
    Ashburn, VA
    You said it happens when you brake. The pads slide on the pins
  5. Jun 19, 2024 at 6:12 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    "When applying the brakes the sound still persists."
    I believe that you misunderstood. On or off the brakes, the sound is still there.
  6. Jun 19, 2024 at 6:26 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    This is a coincidence, mine is making a similar noise at low speed. After trying a few different things with no success, I turn off the AC and bingo, the noise stoped. Its was mimicking the rpm at slow speed.
  7. Jun 19, 2024 at 6:44 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Bearing
  8. Jun 19, 2024 at 6:48 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Mine correlates to wheel speed. It's difficult to hear (especially for my old ears), but at very slow speeds it's noticeable. It's almost sounds like something is rubbing.
  9. Jun 19, 2024 at 6:52 PM
    Biblebuilt4x4
    Biblebuilt4x4 Well-Known Member
    Bill
    2014 Reg. cab 4x4 automatic
    I 2nd the bearing idea. Drivers side is known to go first. Also could be a stuck caliper piston holding the pad against the rotor.
  10. Jun 19, 2024 at 6:57 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Bearing and stuck caliper sound like they are the likely suspects. I'm leaning towards the bearing because the calipers (new Toyota) are less than a year old.
  11. Jun 19, 2024 at 7:01 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Could an overfilled differential or bad/stuck breather cause low speed groans?
  12. Jun 19, 2024 at 7:12 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Unlikely. I don't believe they would produce a mechanical sound like I'm experiencing.
    bkhlrTaco's[QUOTED] likes this.
  13. Jun 19, 2024 at 7:14 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Perhaps I'm thinking of a grumble.
    :notsure:
