Tracktion bars?
Discussion in 'Suspension' started by Bearskill, Feb 19, 2009.
  1. Feb 19, 2009 at 9:19 AM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    If I have pre TSB leaf springs and the Toytec "long" AAL, and some shocks that fit my lift, Can I add the Pro Comp Traction bars with out a prob. Will it change how my rear end flexes? With the traction bars, as the axel drops, wont the traction bars bring the axel forward a bit? Do I need more componants other than the bars and mount plates? Please PM me!!!
  2. Feb 19, 2009 at 9:24 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Why do you think you need a traction bar?
  3. Feb 19, 2009 at 9:27 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Traction bars used with leaf springs, when made properly, will allow fore and aft movement.
    I'm curious to your know the need for them as well. :popcorn:
  4. Feb 19, 2009 at 9:28 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Well, If his is anything like mine, there is a horrible amount or wheel hop off road when you spin tires......
  5. Feb 19, 2009 at 9:37 AM
    Bearskill
    Sac
    Well, in the last couple months I keep feeling, at slowing down to a stop and starting from a stop, a clunk. It's gental, But I can't figure out if my brakes are not appying and disingageing at the same time, or, I am getting axle wrap, or if the auto tranny is shifting realy hard. As chris4x4 suggested I inspeckted my drive shaft and U joints. They are all solid and good to go. So that still leaves me with Tranny, diff, the brake theory, or the axle wrap goinig on. The way it feels, I think it is ether shifting hard or the axle wrap thats going on. I don't beat on my truck at all. I havn't off roaded it hardly at all. I have done a couple of burn outs, but thats about it. The dealer I bought the truck from is a pain in the ass and don't realy want to go to them, but they are the only "Lithia" around. Any Ideas?
  6. Feb 19, 2009 at 9:45 AM
    Janster
    Jandy
    Lancaster, PA
    Another thing to do...is put the truck in Park (or in gear), crawl under the truck and rotate the driveshaft by hand (clockwise or CCW). Do you get any movement out of it? How much? That clunk could be slop in the drivetrain/gears. In combination with a little bit of axle wrap, can give you an even bigger clunking feeling.
    If the driveline is pretty tight.... then I'd suspect you have Axle wrap.
    My 07 shifts hard - it's pretty normal. You could request the dealer check the tranny fluid, but be forwarned, they'd need the truck overnight. The tranny fluid needs to be COLD when they test it (atleast, that's what they told me).
    I'm pretty positive this has nothing to do with brakes.
  7. Feb 19, 2009 at 10:03 AM
    Bearskill
    Sac
    Ya, the drive line thing I did. Just like you said. I had it in park, crawed under and tride to turn, shake, move up, down side to side. No movement except from the carrier barring seal, wich is normal. only about a 1/2 of play. I wish we as owners could check the tranny fluid. This is the first vehical I had that doesn't had a tranny fluid dip stick. Should I just pay for the tranny/diff 30k service? They want $399 for it here in Cali. Im at 34K. I have done every thing my self except the tranny/diff service.
  8. Feb 19, 2009 at 10:10 AM
    Janster
    Jandy
    Lancaster, PA
    What do you mean by 1/2 play - in what?
    YOu have an Auto - no tranny oil service until 100k miles (so they say).
    Diff service you can do yourself - either by checking the fluid level or changing the fluid out completely. Search this forum, there's instructions on how to do that somewhere. Just make sure you know exactly what type of fluid you'd need (for the LSD if you have one).
  9. Feb 19, 2009 at 10:19 AM
    Bearskill
    Sac
    1/2" play in the carrier bearing. The seal. Chris4x4 told my this was normal.
  10. Feb 19, 2009 at 10:29 AM
    Janster
    Jandy
    Lancaster, PA
    That's fine. YOu didn't specify that in the original post.
  11. Feb 19, 2009 at 10:30 AM
    Bearskill
    Sac
    Ya, sorry. The (") makes a bit o diff huh? My bad.
