Traction Aid Devices... post your creative solutions!
Discussion in 'Off-Roading & Trails' started by HalfTaco, Nov 30, 2013.
  1. Dec 3, 2013 at 10:21 AM
    HalfTaco
    HalfTaco [OP] Danger Dave
    Dave
    OC
    02 Single Cab Prerunner
    Hell of a rig. Though I think I can make a rack for mine about a quarter of the size.....maybe haul a spare donut up top. Or a teddy bear. Or half a gallon of water.
  2. Dec 3, 2013 at 10:26 AM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    for the dunes i carry 2 rolls of carpet, 2ft x 10ft, that will get you out of most situations.
  3. Dec 3, 2013 at 10:32 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    :popcorn:
    Anyone here have any experience with the pulpals?
  4. Dec 3, 2013 at 10:35 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I've heard they work well, but they scare me... Haha
  5. Dec 3, 2013 at 10:41 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    been thinking about building a collapsable one. but until that happens, if digging/ramps don't work, it's back to burrying the spare tire in a 3' deep hole, with the winch line on it.
  6. Dec 3, 2013 at 10:48 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Was just about to ask about this. I had looked them up in the past but it sounds like they are hit or miss as to whether or not they'll get you unstuck. Mostly based on manufacturer/design and terrain conditions.
    I was snow wheeling in a remote area of WY and got stuck at the bottom of a hill far from any winch points. After several hours we made it only halfway back up. Sheer luck, we were able to get our gps coordinates out via text. SAR picked us up that evening and we hired a snowcat to recover the trucks.
    In a situation like that, I doubt if those pull-pals would help because of the frozen/rocky soil.
    Would the maxtraxx (or similar) help? Using them in somewhat of a leapfrog technique up the hill? Would you be better off using two sets of them?
    Also, I can't seem to find anyone who sells the Treds? They don't appear to be available on the TJM site.
  7. Dec 3, 2013 at 10:50 AM
    PcBuilder14
    Brent
    Nor Cal
  8. Dec 3, 2013 at 10:53 AM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    Put your hood up, you'll be fine. :rofl:
    Yeah... I read a writeup somewhere, might have been expedition portal, a guy built one and had a lot of troubles getting the angle right. It would either dig too steeply and come over the top or not dig deep enough. I dont have the skills or patience to be successful building one.
  9. Dec 3, 2013 at 10:55 AM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    I've wondered myself about the frozen/rocky terrain, which is what is mostly here, putting them out of commission. Damn high desert anyways.
  10. Dec 3, 2013 at 10:59 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the problem is that the apropriate angle of the blades to each other, and the angle ot the entire unit relative to the pull direction will change based on soil type. you really need to build in adjustments for the blade pitch, and another one on the arm change how agressively it pulls into the ground.
  11. Dec 3, 2013 at 11:01 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I would think the pull-pals would tear the hell out of the ground too. Kinda goes against the whole 'tread lightly' mindset.
  12. Dec 3, 2013 at 11:01 AM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    :goingcrazy:
  13. Dec 3, 2013 at 11:02 AM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    I'm all for tread lightly, but if it means me getting out and going home. I'll do what I need to do.
  14. Dec 3, 2013 at 11:05 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    That's true I suppose. Are there any 'stake' type winching anchors available? Use a 4lb mini sledge to get in in the ground and then a hi-lift to remove it...
  15. Dec 3, 2013 at 11:09 AM
    #35
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    x2. plus you could argue that small hole in the ground is lighter treading than an abandoned vehicle.
    you see that kind of stuff in rocks, but that would really really scare me in soil :eek:
  16. Dec 3, 2013 at 11:10 AM
    #36
    skidooman
    TJ
    Northern Nevada
    19 Taco
    I've heard of guys carrying rebar and pounding it into the ground as stakes.
    There was a link to a thread in a utah off road site, a guy had put his T4R in a bad spot and was in danger of going over the edge. The local guys rigged up some pretty awesome stuff to get him out. I'll see if I can find the story.
  17. Dec 3, 2013 at 11:14 AM
    #37
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    If they're angled enough, I don't see why it would be an issue. :notsure: Use the same thing as those large tents (like you see at the county fairs?).
    Or something like this to keep it from pulling toward you?
  18. Dec 3, 2013 at 11:22 AM
    #38
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    that blade on it is the key. so much force on such a small surface area would be like using a cheese wire depending on the ground conditions. the blade on that spike helps spread out the load. spread out the load enough with a large enough blade, and low and behold, you've got yourself a ground anchor. a spike could also dislodge a lot quicker than an anchor, potentially turning itself into a javelin without warning. could be something to keep in your back pocket as a last resort, but i personally, would exhaust all of my other options before attempting a stake/spike/rebar pull. and even then, i'd toss my spare tire down on the ground and losely strap the spike to the tire, so that if it did break free, there was something to stop if from spearing me or the truck.
  19. Dec 3, 2013 at 11:27 AM
    #39
    skidooman
    TJ
    Northern Nevada
    19 Taco
  20. Dec 3, 2013 at 11:39 AM
    #40
    SierraExp
    SierraExp Its the Journey, not the Destination Vendor
    Sierra Expeditions
    Mesa, Arizona
    We stock and sell both the TREDS and MaxTrax and I will say hands down that MaxTrax blow the treads out of the water.
    TREDs aren't a bad option for their price point but I have found that the will not hold up nearly as long as the MaxTrax will and the construction as others mentions is much thinner than others and I have seen pictures of them cracking or breaking. I have found that the "shovel" end of the TREDs is almost useless and I would much prefer the bi directional option the MaxTrax have.
    http://www.sierraexpeditions.com/index.php?l=product_detail&p=12721
    http://www.sierraexpeditions.com/index.php?l=product_detail&p=1012
