Traction bar options?
Discussion in 'Performance and Tuning' started by WOODEX M.E., Oct 13, 2013.
  1. Nov 24, 2016 at 7:18 AM
    #41
    WOODEX M.E.
    WOODEX M.E. [OP] Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    It might....but its cold out for another 5 months......might have to wait.
  2. Jan 2, 2017 at 10:01 PM
    #42
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    As a first gen that off roads, what I don't like about my bud built is I can't install it yet lolz. It will require that I get a new muffler/cat back. Maybe every truck is different, little bends, exhaust hanger bends etc, but there is now way to 'push' the exhaust over enough to allow fitment of the trac bar. Pretty peeved with this as a) advertised as bolt on and b) I actually don't want to touch my exhaust at all. 18 y/o me would be all over any excuse to mod the exhaust, ~3X me loves the OEM lack of noise.
  3. Feb 16, 2017 at 1:01 PM
    #43
    CheauxxYeauxx
    CheauxxYeauxx Well-Known Member
    Cody
    Nuba, Louisiana
    2009 TRD sport 4x4
    6 inch pro comp lift with the factory installed TRD supercharger
    I have a set of the pro comps on my 6 inch lift, I wouldn't have a truck without them now a days, when I was a teenage I would go through so many rear ends from everything shifting
  4. Sep 19, 2018 at 9:31 PM
    #44
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Bump for more options.
    I'm not a fan of the bud built design because it uses the studs for the pumpkin. Torque spec for those is only 33ft/lbs.
    My truck goes off-road tho so not willing to sacrifice ground clearance.
    No money for a proper linked long travel setup. Just looking to stop axle wrap
  5. Sep 20, 2018 at 7:50 AM
    #45
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Get a weld-on version and pay a friend to install if you don't weld.
  6. Oct 12, 2020 at 9:14 AM
    #46
    hresendiz25
    hresendiz25 Active Member
    Horacio
    Arizona
    2009 Toyota Tacoma 4x4 Double Cab
    URD Fuel Pump
    OP,
    Were low speed vibes all you had before installing the Caltracks?
    I am on a quest to reduce (and hopefully eliminate) high speed vibrations on my 2nd gen.
    I was thinking on giving these Caltracks a try​
  7. Oct 12, 2020 at 7:38 PM
    #47
    WOODEX M.E.
    Corey
    Maine
    Yeah, the vibration was from accelerating hard and getting axle wrap, a common issue. If i accelerated gently or was driving at any other higher speed there was no vibrations. The traction bars only functioned to reduced the axle wrap from acceleration.
    hresendiz25[QUOTED] likes this.
  8. Oct 13, 2020 at 6:11 AM
    #48
    hresendiz25
    Horacio
    Arizona
    URD Fuel Pump
    This is exactly what is happening to me.
    The vibrations don't get too bad for low speeds, but on the highway it can get pretty bad. I even got a Tom Wood's driveshaft. They have been very helpful throughout the process though. I am just waiting for my new leafsprings to test that before ordering the Caltracks. I still have the 3 leaf set, so the new pack is a 4 leaf set.
    Thanks for your response!​
  9. Oct 20, 2020 at 10:02 AM
    #49
    hresendiz25
    Horacio
    Arizona
    URD Fuel Pump
    I think I am ready to try the Caltracs. I totally forgot about these posts on quotes.
    Did you manage to get rid of the rattling noise?
    Or maybe figured a way to keep the bolts from loosening?
    Thanks​
  10. Oct 20, 2020 at 3:19 PM
    #50
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Caltracs are noisy and squeaky. Unless you need them for drag racing, you probably should look somewhere else. I haven't read all 3 pages, but you can use a clamp just forward of the axle. Lots of drag racers using a clamp to reduce wheel hop. Only costs a few bucks.
  11. Oct 20, 2020 at 3:27 PM
    #51
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    I used to have caltracs on my old tacoma, they held up pretty good, but I had a lowered prerunner.
    hresendiz25 likes this.
  12. Oct 20, 2020 at 6:08 PM
    #52
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The heim joints can always be changed to the nylon or whichever insert style.
    WOODEX M.E.[OP] and hresendiz25 like this.
  13. Oct 28, 2020 at 7:37 PM
    #53
    WOODEX M.E.
    Corey
    Maine
    Never did. They got to a point and just never got worse and asnt really that bad. The heim joints did wear out eventually. I put about 105k on my set before i removed them for a lift.
    Biscuits and Torspd like this.
  14. Oct 28, 2020 at 8:00 PM
    #54
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I've had mine on foe a number of years, of which I would have to look back to determine. However, mine being a street truck, and my driving style, hasn't exacerbated their wear.
    Biscuits likes this.
  15. Oct 28, 2020 at 8:04 PM
    #55
    WOODEX M.E.
    Corey
    Maine
    I was surprised to see you still here doing your thing. I haven't been on here much in the last couple years. I daily the Tacoma now so i have basically left it be. My current project is a 335xi with a Precision 6266. Now thats speed my tacoma could never achieve.
  16. Oct 29, 2020 at 4:11 AM
    #56
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :cheers: mate. Still enjoying the adventure of the curriculum that the Tacoma offers me. :D
    Now that car is a zinger with that setup! I can only imagine what my little 328IS will be like with a similar setup. Especially since it is already track prepped.
    Makes me want to lift the truck back up at times. Then I'd have both lifted and lowered turbo vehicles. Ahhh
  17. Nov 3, 2020 at 7:50 PM
    #57
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Speaking of being surprised people are still around... Glad to see you're still lurking. :)
    Or you can buy my PreRunner and have a lifted and lowered Tacoma...
    BassAckwards likes this.
  18. Nov 3, 2020 at 7:52 PM
    #58
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Quite the generous offer. One Tacoma is enough for me though. :cheers:
  19. Nov 3, 2020 at 7:57 PM
    #59
    Biscuits
    I'm a generous guy.
  20. Dec 3, 2020 at 3:48 PM
    #60
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I just tried this and it seems to work great on my bagged stock leafs. Stiffened up the rear suspension and it seems more planted at the same time. Pretty awesome for $20.
