Traction Bars for 2016+
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Myles G, Sep 13, 2019.
  1. Sep 13, 2019 at 7:00 AM
    Myles G
    Myles G [OP] Well-Known Member
    Myles
  2. Sep 13, 2019 at 8:23 AM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Id recommend finding another option, probably from a different truck. Had this trac bar for a little over a year, the bushings started to go and it was making my ride much bouncier than normal despite trying to adjust my shocks to make up for it. It also bent the crossmember that it mounts to on my truck, not past the point of elastic deformation but it did take a good knock and hit the bottom of the cab. Not a huge deal since it bent back by itself, and because the crossmember only holds the carrier bearing and the carrier bearing can be adjusted, but the design on the budbuilt trac bar is not adequate.
  3. Sep 13, 2019 at 8:28 AM
    Myles G
    Myles
    So you had the 2nd gen one on your 3rd gen?
    Ive heard good and bad things about it on the 2nd but your the first ive seen to have it on a 3rd gen
    can I go to a shop and have one fabbed for less than a grand?
  4. Sep 16, 2019 at 2:46 PM
    stevotivo12
    Stephen
    Most likely, yeah. I wouldn't think it would cost more than that
  5. Sep 16, 2019 at 3:19 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Why not SUA with a leaf pack that has a anti-wrap half leaf?
    Ladder bars just seem wrong on a 4x4 truck, IMO
    Skydvrr likes this.
  6. Sep 16, 2019 at 5:30 PM
    Myles G
    Myles
    Yeah to be honest they just look badass but I am just getting my ducks in order for boost
    I’ll start with cab mount chop, clutch and flywheel
  7. Sep 17, 2019 at 7:28 AM
    stevotivo12
    Stephen
    Don't even need the anti-wrap half leaf, SUA alone does enough. Im running the Archive Garage setup with SUA, hammer hangers, bed cross bar, and high strike plates for air bumps. No appreciable axle wrap with this setup even after removing the T bar, plus the ride is much improved with the increase in suspension travel
  8. Sep 17, 2019 at 7:30 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    We have leaf springs. No reason to have a traction bar.
  9. Sep 17, 2019 at 7:31 AM
    stevotivo12
    Stephen
    except for axle wrap.
    GreyBaldTaco likes this.
  10. Sep 17, 2019 at 7:36 AM
    JoeCOVA
    Joe
    Colorado Springs
    Should have very little of that. Guys are are wheeling hard with SOA to include myself with no issues.
  11. Sep 17, 2019 at 7:37 AM
    stevotivo12
    Stephen
    axle wrap happens when launching, not wheeling. It would be most apparent as a hop accompanied with a skipping tire skid pulling away from a stoplight, along with greatly reduced power
  12. Sep 17, 2019 at 7:38 AM
    JoeCOVA
    Joe
    Colorado Springs
    Yup should be very little of that. Guys are running lower gears and applying more torque to the rear without issue.
    If anything just upgrade the leaf pack.
  13. Sep 17, 2019 at 7:43 AM
    stevotivo12
    Stephen
    Already went SUA to fix the issue I was having with axle wrap personally. Just for the record, its mostly the lack of torque that causes the issue here. The motor doesnt have quite enough torque to properly launch the taco and the result is that the rear wheels dont cleanly break free, they intermittently break free. Combine this with leaf springs and what you get is a lot of wheel hop and axle wrap. It can be fixed by 1) adding a traction bar 2) going SUA 3) adjustable shocks can dampen the oscillations and make things much smoother, maybe even legit eliminate it as well.
  14. Sep 17, 2019 at 7:52 AM
    JoeCOVA
    Joe
    Colorado Springs
    Ya that’s super weird, I know it happens but should be rare. I plan to go to a SUA sometime, I never liked SOA designs.
  15. Sep 17, 2019 at 7:56 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    What are traction bars going to do to benefit a Pro? Some people are removing their sway bars for better flex. I wouldn’t have even thought a Tacoma has enough torque, even when boosted, to use those.
    Not criticizing, just curious...
  16. Sep 17, 2019 at 7:59 AM
    stevotivo12
    Stephen
    Its not the motor having torque thats the issue, its the other way around. The motor has too LITTLE torque, and the wheels, tires, lift, length of driveshafts, terrible factory gearing, etc is too much to overcome. The traction bars attempt to make the rear end more rigid so it is easier to send power through, however, as I mentioned before it is a better solution to spend the same money upgrading your leaf springs to SUA big leaf packs if you really want that performance. You get the flex to handle offroad with the rigidity to handle power.
  17. Sep 17, 2019 at 8:01 AM
    Myles G
    Myles
    Make me look cooler:rofl:
  18. Sep 17, 2019 at 9:08 AM
    OnHartung'sRoad
    :cool: :notsure:
