Traction Board Review... Tred, Maxtrax, Traction Jack, Maxsa
Discussion in 'Recovery' started by Mademan925, Jan 19, 2017.
Which boards are best for your overlanding style?
  1. Maxtrax
    51.8%
  2. Tred 4x4
    11.7%
  3. Traction Jack
    3.1%
  4. Maxsa Innovations
    17.1%
  5. Other- tell us why!
    17.9%
Multiple votes are allowed.
  1. Feb 7, 2020 at 11:29 AM
    #141
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I will spam some more info on my USAction Trax
    Now I have 4 of them, since my set that has slight cracks are still fine, the cracks are not growing or turning into splits. I have used them many times since I noticed the problem.
    I decided to upgrade them for traction on snow and ice, since that is where I have been using them. I took the idea of replacing the top studs with nuts and bolts, and did the bottom teeth that grip the ground. They no longer want to slide out from under the tires while gaining traction. It kinda makes them not stack as great since the nuts and bolts protrude a bit on the bottom more, but its worth it for me.
  2. Feb 12, 2020 at 5:04 AM
    #142
    665.0coupe
    665.0coupe Well-Known Member
    Luke
    Kansas
    2020 DCSB OR MT
  3. Feb 13, 2020 at 10:08 AM
    #143
    llamasmurf
    Wes
    Northern Ontario
  4. Feb 13, 2020 at 10:16 AM
    #144
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    llamasmurf likes this.
  5. Feb 28, 2020 at 1:04 PM
    #145
    EZE
    EZE Well-Known Member
    E
    Ludington
    2020 Taco SR5 DCLB
    Feel better about my Tred Pro's Amazon purchase for $227.93 after watching Ronnies video thanks for posting @665.0coup.
  6. Dec 2, 2020 at 6:24 AM
    #146
    Boonedoggle
    Boonedoggle Well-Known Member
    Lincoln, NE
    2012 DCSB TRD
    None.... Yet
    I read a lot from folks that say "If I'm going to spend $250 on ActionTrax I might as well spend another $50 and go with MaxTrax, I known entity." I too hold that sentiment though I really like the idea of going with a local company. I'm curious, what would the price be where folks would choose ActionTrax over MaxTrax?
    Kronk21 likes this.
  7. Dec 14, 2020 at 5:05 PM
    #147
    TacoDDS
    TacoDDS Well-Known Member
    2017 SR5
    Amazon X bull - No go, had them snap in sand first use and have heard of the same thing happening to other people before
    bonnfabrication and CowboyTaco like this.
  8. Jan 16, 2021 at 10:49 PM
    #148
    bonnfabrication
    bonnfabrication Well-Known Member
    Brandon
    Bremerton
    2018 Tacoma TRD OR DCSB 4x4
    Dobinsons HD MRR lift SCS F5 wheels BFG K02s front bumper, custom roof rack
    Damn glad I read through this or at least skipped to the end. I was just looking at those today. Good to know before I bought them.
  9. Feb 9, 2021 at 3:20 PM
    #149
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    But the bridge test...
  10. Mar 1, 2021 at 10:28 AM
    #150
    MtRainier
    MtRainier Well-Known Member
    Randy
    Seattle, WA
    2021 Super White TRD Off-Road 4X4
    Has anyone given in to the Instagram marketing and bought those “Go Treads” that keep getting spammed in my feed?
  11. Mar 1, 2021 at 10:45 AM
    #151
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    No, but my wife has bought a couple of the instagram marketing items and been disappointed with every. single. one.
  12. Mar 4, 2021 at 11:38 AM
    #152
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    2024 Celestial Silver DCSB TRD OR Hybrid
    So I managed to get my truck stuck in muddy snow last weekend and ended up tearing up my floormats getting out...am I right that the consensus is the Maxtrax are the way to go for snow/cold weather use?
  13. Mar 5, 2021 at 4:39 PM
    #153
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    i can vouch for the maxsa metal grip escaper buddies. they got me right out of some deep sand in anza borrego this past weekend. and i was hooked up to my camper trailer. they saved my ass for sure!
  14. Mar 22, 2021 at 4:35 PM
    #154
    aceman4
    aceman4 Well-Known Member
    South FL
    2018 DCSB 4x4 Off Road - Cement
    Are the mounting hole dimensions the same between the Maxtrax and Action Trax? I have a Uptop bed rack and the mounts are specific to Maxtrax
  15. Mar 28, 2021 at 10:26 AM
    #155
    Kwikvette
    Fresno County
    4 run, 2 don't
    Went with Maxtrax and they are clutch -
  16. Apr 1, 2021 at 7:11 AM
    #156
    Bcoyle3400
    Bcoyle3400 Well-Known Member
    Has anybody tried the rotopax boards? Look like a good deal minus the price for their mounts.
  17. Apr 12, 2021 at 8:26 AM
    #157
    llamasmurf
    Wes
    Northern Ontario
    Yes its my understanding they are the same.
    Kronk21 likes this.
  18. Apr 25, 2021 at 2:43 PM
    #158
    UMC
    UMC I will not comply
    Thomas
    South Fork of the American river.
    13 TRD Sport DCLB 4x4
    37's & rear locker
  19. Apr 25, 2021 at 6:25 PM
    #159
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    So is it just a matter of having "something" and not necessarily a certain brand?
  20. Apr 26, 2021 at 12:27 PM
    #160
    CowboyTaco
    North Georgia
    11 TRD Sport
    My take on them is that you can spend top dollar on MaxTraxx and get the ones that will last the longest and take the most abuse. That's worth it if you constantly find yourself in situations where they would come in handy.
    On the flip side, you can save a decent amount of money and get some of the cheaper alternatives that might not last more than 1 or 2 uses. If it's likely a single use item for you, then save the money and get the cheap ones. But if you break more than 2 sets, you should have just gotten the good ones from the beginning.
