Traction Boards help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Leggo, Dec 27, 2015.
  1. Dec 27, 2015 at 8:15 PM
    Leggo
    Leggo [OP] slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I want a pair of good quality traction boards but I want them to be about 5 feet long so I can use them as a light weight ramp to the bed. Any sources or advice is welcome. I want them for snow exclusively.
  2. Dec 27, 2015 at 8:32 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    If you need to have them be 5' long for traction I think you your only option may be sand ladders. If you want to drive something heavy into the bed you may be further limited to bridging leaders. I don't think either of them really designed to work well for snow traction and recovery. If you can live with 45" to 48" there are lots of traction options from Maxtrax, Smittybilt, and others.
  3. Dec 27, 2015 at 8:56 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
  4. Dec 27, 2015 at 8:58 PM
    Pigpen
    Dan
    Northwest Montana
    2 x 12 lumber with smaller lag bolts (for traction) are the answer.
    blu92in99, IronPeak and archerm3 like this.
  5. Dec 30, 2015 at 2:38 PM
    Leggo
    Newton,Ma.
  6. Dec 30, 2015 at 5:35 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Now go drive it into a snowbank so you can give us an evaluation. :). I've had these in my Amazon shopping cart for a week and haven't pulled the trigger. Yet. http://www.amazon.com/Smittybilt-2790-Element-Traction-Ramps/dp/B005QAMV1K
    Arcticelf likes this.
  7. Dec 30, 2015 at 5:48 PM
    Leggo
    Newton,Ma.
    I plow snow and every once in a while i will lift the blade just a little too early and end up high centering myself in the bank I am trying to build. The plow then becomes an anchor and shoveling doesn't help to much unless you shovel all the snow behind the blade. I know all the tricks but sometimes it's just fubar. I only do my drive and my folks these days. Last year we had some BIG banks, I think they will work very well tho.
  8. Jan 4, 2016 at 8:36 PM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Maxtrax are some of the best imo
    This are mine. First and only (as far as I'm aware) in the U. S.
  9. Jan 4, 2016 at 8:43 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    I think they probably are the best but I am just to cheap to pay their price right now. I was going to buy the Smittybilts until I started reading the reviews. Ended up ordering Lite-Way Recovery Mats instead of Maxtrax for about 1/3 the cost. Might only last through one, or part of one, recovery though.
  10. Jan 4, 2016 at 8:55 PM
    GARSHA91
    Chicago
    Yea. I'd just rather buy ones that will last. I have seen tires slip and ruin the traction so they're useless
  11. Jan 4, 2016 at 10:02 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    If you can find some, fiberglass (FRP) mesh grating is extremely strong and flexible and provides good grip and isn't too expensive.
    MolonLabeTaco likes this.
  12. Jan 4, 2016 at 11:58 PM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
  13. Jan 5, 2016 at 8:51 AM
    Leggo
    Newton,Ma.
  14. Jan 5, 2016 at 5:42 PM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Great idea !
  15. May 30, 2016 at 9:35 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    Have you used these yet? If so, how did they fare?
  16. May 30, 2016 at 10:09 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Not yet. Ive tried to get stuck but no dice with the locker and ATRAC :) The weather is nice now so will just have to go out to the sand (lots of it around here) and stick the thing just to try the boards. IT Will really hack me off if they shatter like I read the Smittybilts have a tendency to do. Guess it will be better to know that now than later on the back side of a mountain somewhere at o-dark thirty.
    tacitos[QUOTED] likes this.
  17. Jan 15, 2019 at 3:11 PM
    Breakr007
    Breakr007 Well-Known Member
    I know this is a way old post, but how did these liteway tracks work out for you? I too, am poor.
  18. Jan 15, 2019 at 7:18 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Only used them once and they didn't break but had some minor deformatiin. Only one use is a poor sample size, sorry.
