Traction/check engine light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Miles_clinton, Oct 23, 2019.
  1. Oct 23, 2019 at 6:35 PM
    Miles_clinton
    Miles_clinton [OP] Well-Known Member
    Miles
    2009, metallic grey, Tacoma, access cab, manual, v6, TRD Offroad
    TRD Cold air intake, Icon vehicle dynamic coil-overs, XD series monster II, pedal commander, skid plate, alarm, borla cat back
    7E1A3FE6-6426-463E-B91B-1B9C20C87EF0.jpg B19E451F-052D-4F53-AE2D-45A27D598277.jpg After cranking up my 09 Tacoma 4X4 4.0 MT 140k miles tonight the traction control & check engine light came on. These are the codes. Please advise
    Thank you,
    b
  2. Oct 23, 2019 at 6:37 PM
    Tanselow
    Tanselow Well-Known Member
    22 trd or
    Have you done any recent front suspension work? Try searching vsc recalibration.
  3. Oct 23, 2019 at 6:55 PM
    Miles_clinton
    Miles
    I just had the rack & pinion replaced last week.
  4. Oct 23, 2019 at 6:57 PM
    Tanselow
    22 trd or
    My truck went into a limp mode when I left the alignment shop, turns out they didnt reset the vsc. I reset it and all was good.
  5. Oct 23, 2019 at 8:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  6. Oct 23, 2019 at 9:11 PM
    AppleJax
    AppleJax Active Member
    I had this one time and it was the gas cap having a bad seal, after I replaced the gas cap, disconnected the negative side of the battery and reconnected then it went away. The second time it was after a heavy day of off-roading and my after market intake filter had come off so I was sucking in unfiltered air for a few hundred miles and it dirtied up my mass air flow sensor. I pulled it, cleaned it up with MAF cleaner. Re-installed everything and it was good to go. Could also be VSC though. Be interested to see what it was for you.
