Traction control, abs, parking brake light issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gordi, Mar 10, 2014.
  1. Mar 10, 2014 at 8:52 AM
    gordi
    gordi [OP] Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    So i was driving to work this morning and when i came to a normal stop at a light my traction control light, abs and parking brake light all came on? Never had this issues before and my truck has not had a mod in over a year. Everything still worked fine and i could stop. I shut it off and that cleared the problem all the lights work when they are supposed to now. Also it was pouring rain here for a week now but i checked all my fluids and everything was fine and dry?
    2011 trd sport dbl cab
    6 speed v6 4x4
    25k miles
    bilsteins all around, trd intake, Borla exhaust.
  2. Mar 10, 2014 at 9:26 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Bump no one have this issue?
    Happened again on the way home when i went to stop it all turned on but everything worked still?
  3. Mar 10, 2014 at 10:41 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    There's lot of reasons the ABS / VSC system would log a fault code and turn the warning lights on, you'd have to read the codes. Since the code has gone inactive and the lights are now out, it might not be a big deal, though if it were mine, I'd probably retrieve the fault info for peace of mind.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/318614-electrical-issue-abs-issue.html
    Another recent thread on the same topic, and it contains info of retrieving the fault code via a "blink code" on the dash light. It most likely isn't the same failure though.;)
  4. Mar 10, 2014 at 10:46 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Mine throws those lights when any speed sensor get unplugged or isn't reading. Did you still have speedo? The rear will take away the speedometer.
  5. Mar 10, 2014 at 11:16 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    ya truck is stock mostly. speedo is there. Never had this issue and owned this truck for 2 years its just a DD half the year when my motorcycle isnt rideable.
  6. Mar 10, 2014 at 11:40 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    but it all goes off after i shut the truck off as well and i drove it later tonight and it didnt come on. Its just the traction control light with the tire marks the abs and the parking brake light that come on and stay on until i shut it off.
  7. Mar 10, 2014 at 11:46 PM
    LuckyCharms
    LuckyCharms Knows a little about a lot
    Socal
    '13 PreRunner TRD dclb
    Sounds to me like you have a short or loose wire on one of your sensors. Most of the time it reads fine, but when the ECU doesn't see a sensor for a split second, it throws up all the lights and codes.
  8. Mar 11, 2014 at 7:24 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    lets hope so. idk where to even start checking that stuff.
  9. Mar 11, 2014 at 9:43 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    also this morning i started the truck and was looking under the hood for anything out of place on the abs. No light on then when i shut the hood they turned on. so i tried it again and when i shut the hood it did it again....im assuming a loose wire somewhere.
  10. Mar 11, 2014 at 12:24 PM
    nfs257
    DFW
    She gone
    Check the relay that is under the hood in that fuse block? If you pull it you can turn ABS off. Maybe it is loose.
  11. Mar 11, 2014 at 1:47 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    ill check it. wonder how the hell it would get loose truck is super clean and barely has 25k miles on it.
  12. Mar 11, 2014 at 4:48 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    Would this be related to the recent recall?
  13. Mar 11, 2014 at 5:03 PM
    nfs257
    DFW
    She gone
    Then take it in and show them for the warranty.
  14. Mar 11, 2014 at 5:28 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    what recall?
  15. Mar 11, 2014 at 5:28 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    its a 2011 so my warranty is up bc its 36k miles or 3 years.
  16. Mar 11, 2014 at 5:37 PM
    Tacoma Mike
    Southern Maine
    Don't touch it.
    Don't pull relays
    Don't pull fuses.
    Take it in and have it checked.
    Lots of reasons for this.
    Some simple some not.
    Don't do something that will cause a false reading or code that can send someone down a wrong repair path.
  17. Mar 11, 2014 at 7:45 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Great advice. If you're not going to read the blink codes with the info I posted, then follow this advice.
  18. Mar 12, 2014 at 10:17 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    eh found out its under warranty until june 8th. so its going in and they can deal with it also getting the fan blower motor tsb done!
  19. Mar 12, 2014 at 10:29 AM
    nfs257
    DFW
    She gone
    :woot:
  20. Mar 20, 2014 at 10:16 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    so i had a severed wire above the rear differential that corroded and fell apart thats why my lights were coming on. They also did the tsb fan blower motor. Idk how the wire got severed but they fixed it all up and clean now. love warranty.
