Traction control and check engine light on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kevintreb, Nov 15, 2022.
  1. Nov 15, 2022 at 9:15 AM
    Kevintreb
    Kevintreb [OP] Member
    Kevin
    2017 Tacoma Trd sport 4x4
    I have a 2017 Tacoma Trd sport 4x4 manual transmission and I’ve had a code p0607 check engine light and traction control light on the past few days. This code is for the pcm has anyone else had this problem?
  2. Nov 15, 2022 at 9:21 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    It's a non-Toyota specific error code for the PCM(engine computer).
    is the truck doing anything weird?
    I would clear and it see if it comes back. If the same code appears I would have someone diag it who has the proper scan tool.
  3. Nov 15, 2022 at 9:34 AM
    Kevintreb
    Kevin
    It’s intermittent but it has been coming back with the same code several times
  4. Nov 15, 2022 at 9:37 AM
    eurowner
    eurowner Duke Sky
    Scoty
    What have you changed out or installed?
    You always can remove battery negative for 15+ minutes and give it a go after.
  5. Nov 15, 2022 at 9:41 AM
    Kevintreb
    Kevin
    I had to put a new battery in it yesterday, the one that was in it was going bad and I was hoping that the batter was the cause of the CEL but it wasn’t left the battery unhooked for about 20 minutes hoping that would clear it out but it didn’t other than that nothing has been done to the computer system in the truck
  6. Nov 15, 2022 at 9:43 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Same happened to me. The CEL and trac off usually come up as a pair. I scanned my codes but it said bad crank position sensor. When I saw what was involved, I started looking closely and noticed rodent debris in places. Found that a mouse had chewed on wiring harnesses causing the fault.
    Not saying that’s what happened in your case, but Im glad I didn’t start replacing parts as that wouldnt have helped. Sometimes getting a proper diag will save you time and $$.
  7. Nov 15, 2022 at 9:58 AM
    Kevintreb
    Kevin
    That’s what I’ll probably end up doing I’m just trying to see if anyone else has had this problem seems like the truck is too new for it to already be having computer issues
  8. Nov 15, 2022 at 10:05 AM
    eurowner
    eurowner Duke Sky
    Scoty
    It is known that there was a batch of bad cam position sensors on the '16 and some '17.
    Bring it to a competent Toyota mechanic of your choice, don't point, blame, and throw parts until you have a proper diagnosis.
    https://www.yourmechanic.com/articl...t the P0607 code means,to do its job properly.
