TRACTION CONTROL IS THE DEVIL!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rodney, Jun 8, 2013.
  1. Jun 8, 2013 at 3:11 AM
    rodney
    rodney [OP] Well-Known Member
    Toyota Sienna Mommyvan & Ford 2fitty
    traction control is the devil. seriously, it tried to wreck my truck numerous times. this last time i really wanted to just burn it. tacoma traction control engineers should be shot.
    vehicle: 11' AC SR5 w/ billy 1.75, tsb spring, 16x8 w/265/75 duratrac, 30k miles
    me: long time SCCA racer with many race wins/championships. i can wheel a vehicle pretty darn well...
    road: typical "S" turn, negative camber both ways due to road crown. speed limit 30.
    scenario: while navigating the road, wet or dry with traction control enabled, mid corner, constant throttle or coasting at speeds 25~30, no tire squeal, no drama. without warning, the traction control would start beeping and the abs would cycle and push the truck wide. finally it calms down and i regain control. scared the sh!t outta me every times it happens. truck always pushes wide when the abs cycles, even while holding a constant arc.
    so, you think i should just go slower? yeah, i guess that i could put in in 4low and granny it around. must be a slick corner, right? not really.
    there was little traffic this morning, so i went back and forth a bunch of times to test. i tried it with the first stage of traction control disabled. same thing. truck gets wonky with beeping/abs.
    i disable traction by stopping the truck and holding the button down for 5 sec. i go through the corner same speed. nothing. i spin around and do it again, going 10 mph faster. nothing. i spin around and go even faster, with a hint of understeer, still no drama. same throttle input, same steering angle, same everything, just with the button disabled.
    ok, now i am perplexed. i enable traction control again with a restart, and go through at 25 mph, same line, and the truck freaks out again. :confused:
    it is downright dangerous. i could see if i was going 50mph, truck sliding and the traction control "trying" to protect me from myself. i could picture my wife driving in the same scenario, truck freaks out and she applies too much steering angle and shoots to the inside and hits a guardrail when traction control hands back control... not cool.
    anyone else have this issue? or is my truck possessed?
  2. Jun 8, 2013 at 3:15 AM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    Mine does that to. I hate it myself. It ruins the fun haha
  3. Jun 8, 2013 at 3:33 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Had TC in the Tundra's, all 3, now in the '12 Tacoma. This system is more dangerous then good. Sucks on road, sucks off road, just plain sucks. I'v had Toyotas for like 20 years now, if they keep this bullshit system I'll never buy another.
  4. Jun 8, 2013 at 4:15 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You may need to have the traction control calibrated. Sometimes after lifting the trucks, the pitch and yaw sensors get screwy and the traction control does not work correctly. There is a way to do it on your own if you have the little plugin tool. Its explained on this site somewhere. Otherwise I think the dealership can do it. It's definitely something to look into because as you have experienced the traction control out of whack is dangerous.
  5. Jun 8, 2013 at 4:20 AM
    moondeath
    Pa, Gardners
  6. Jun 8, 2013 at 4:40 AM
    drunktaco
    Sage
    Southwest Va
    Is there a way to disable it or anything like semi permanently or something? Kind of like the abs mod, rig it to a toggle switch? I mean, I know hold it in for 5 sec ect. but another way to where i could flip a switch and it'd be gone. Anyone have any idea haha
  7. Jun 8, 2013 at 4:51 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  8. Jun 8, 2013 at 4:57 AM
    drunktaco
    Sage
    Southwest Va
    Sweet. So I can do the abs mod and I'm traction control free. I knew that's how it worked but I didn't know if there was anything else there with it. Thanks Oz
  9. Jun 8, 2013 at 5:10 AM
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  10. Jun 8, 2013 at 5:19 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    You probably should report this to the government. Here is a link.
    https://www-odi.nhtsa.dot.gov/ivoq/
  11. Jun 8, 2013 at 5:22 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    make sure your truck is perfectly level when u re calibrate it
  12. Jun 8, 2013 at 5:22 AM
    OZ-T
    Peter North
    British Columbia
    wut
    " hi I lifted my truck and now the VSC system that was calibrated for the stock geometry doesn't work properly "
  13. Jun 8, 2013 at 6:16 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    ^^This!
    I was thinking the same thing. Mine still sits on the "Stock" TRD suspension and I've only seen mine go off while in the snow. Not the engineers fault if you lifted it. Don't get me wrong... There is nothing wrong with lifting your truck you just can't blame Toyota for something that you have changed and now your truck isn't calibrated for that change. JMO
  14. Jun 8, 2013 at 2:04 PM
    rodney
    i had the tsb springs put in, and it was sky6high in the back, so i put the billy in and it was nearly the same rake it was before. i had the truck new and put that springs in very early, so most of it's life it was mini lifted.
    i will look into the reset procedure. i will update with the results.
  15. Jun 8, 2013 at 2:25 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    abs/trac kill switch FTMFWMF!
  16. Jun 8, 2013 at 2:30 PM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    I hate traction control, abs & all electronic devices that are designed to help us drive our trucks. Please, let me drive my truck myself.
  17. Jun 8, 2013 at 4:38 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    You have to remember it is designed for the 99% of retards on the road that do not know how to drive in emergency situations.
    Some people just have the correct natural response to a slide out and if you are one of those people then the TC/ABS/VSC will just fuck you up.
    They are really good systems for most people that are stupid drivers and just brake harder in these instances.
    Me personally I don't have a problem with the systems they work great for me because I know this and adjust my driving to suit them.
  18. Jun 8, 2013 at 4:56 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I smell lawsuit... they didn't mention anything about that in my owners manual! :facepalm:
  19. Jun 8, 2013 at 5:06 PM
    OZ-T
    Peter North
    British Columbia
    So , you are calling yourself one of the 99% of drivers that are retards ?
    Legit
  20. Jun 8, 2013 at 5:15 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    I can't disable my system on my 13'... Ill have to read some threads because I hate that MF POS Trac control!!!! I'm fine with ABS, but I f-ing hate when my truck tries to drive itself! I can't even spin my truck around in 2' of snow...
