TRACTION CONTROL IS THE DEVIL!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rodney, Jun 8, 2013.
  1. Jun 8, 2013 at 5:48 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    There's times I like the nanny, there's times I don't. I was moving fast on a dirt road in Utah last year, I mean MOVING, thought I knew the road, but no I didn't, came upon a surprise 90 degree turn. I was doing 60 mph in 4HI, and I hit the brakes hard. I really do believe if it wasn't for the VSC and the ABS I would have gone right through that corner and into the ditch. I slammed on the brakes and put the clutch in, and I felt OK, the brakes were pulsing, the steering felt manageable, I downshifted out of sixth into 4th. I liked the nanny that day.
  2. Jun 8, 2013 at 6:28 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes you can
  3. Jun 9, 2013 at 4:42 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Thanks for edumakating me... Derrrr...
    Tried it last night and bingo! Going to get it in some dirt and mud today and test it out
  4. Jun 9, 2013 at 8:13 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    No what I am saying is you are retarded and can't figure out how to use the systems so you take the cop out and cut the wires to disable it.
    So....basicly I am say I am smarter than you because I understand how the systems operate and I am able to adjust my driving style to compensate for them and not whine like a little bitch like you.
    You give Canadians a bad name.
  5. Jun 9, 2013 at 8:38 AM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    I can't even go off a curb wrong without that fucking beeper going off! Time to disable.... :mad:
  6. Jun 9, 2013 at 8:41 AM
    OZ-T
    Peter North
    British Columbia
    :yawn:
    TLDR
  7. Jun 10, 2013 at 6:58 AM
    teneighty
    Wow! That's crazy! I wish I knew how the computer was going to make my truck react every time. you must have special powers!
    I agree that it will help a lot of people that aren't the best drivers.
    So when you say you adjust your driving to suit the system... You drive on paved roads everywhere you go and never drive in a way that will cause a tire to loose traction? The system is too sensitive and restrictive to do any type of driving other than "grocery getting grandma" type driving.
  8. Jun 10, 2013 at 7:08 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yep^.
  9. Jun 10, 2013 at 7:12 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you fight the system it's going to fight back. Let it do it's thing and they work. Most people do not know how to control a sliding truck so the system does it for them.
  10. Jun 10, 2013 at 7:14 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yep lifted mine a whole inch.
  11. Jun 10, 2013 at 8:45 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    to OP
    1) It shouldn't do that
    2) yes have VSC recalibrated at a dealer and tested (sensor diagnostics)
  12. Jun 10, 2013 at 1:30 PM
    monkeyface
    Colorado
    Well, lets look at it this way - the World Rally Car guys loved their electronic nannies like VSC, ABS back in 2010 because it was so much easier to drive fast on loose traction surfaces. They removed all the nannies in 2011, said ABS, traction control, etc, made it "too easy" to drive the cars. Doesn't that tell you something, like maybe it's good to have the nannies?
    You have to learn where your threshold is for when the ABS kicks in. I have to mash pretty hard on the brakes to get the ABS to kick in, I can feather the brakes just fine and avoid the ABS.
    VSC, well, that can be a PITA. Yeah, I agree the VSC is too sensitive.
  13. Jun 10, 2013 at 1:48 PM
    monkeyface
    Colorado
    In fact there's times where even the best race drivers in the world wished they had ABS. Trying to correct a slide while at the same time downshifting and pumping the brakes is absolutely not an ideal situation.
  14. Jun 10, 2013 at 1:48 PM
    teneighty
    I'm not talking about ABS. Nobody can brake better than the ABS system can. But the Trac control can't determine all factors that the driver knows or see's ahead of them. Like I said before, some people that don't have the best driving skills or that are oblivious to anything other than themselves while on the road do need this system.
  15. Jun 10, 2013 at 1:50 PM
    #35
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Don't blame Toyota.
    "The NHTSA requires all new passenger vehicles to be equipped with ESC by 2012 and estimates it will prevent 5,300–9,600 annual fatalities once all passenger vehicles are equipped with the system."
    It's the government that is cramming this down our throats.
    I would also like to turn my mower on and off as I would like instead of a kill bar. I'm smart enough to not stick my hand down the shoot or foot under the deck.
    I know how to use wood cutting equipment without a kick guard. It gets in the way. I've been using equipment for 40 years without a problem. The kick guards just get in the way.
    What about forced helmet laws. We should have the right to not wear them. (But insurance should not cover injuries if you aren't wearing one, IMO).
    There are tons of other policies to keep the masses so called "safe". It's the government not the manufactures.
  16. Jun 10, 2013 at 1:54 PM
    #36
    OZ-T
    Peter North
    British Columbia
    Who's talking about ABS ?
    The OP is talking about VSC over-sensitivity caused by his lift
  17. Jun 10, 2013 at 2:13 PM
    #37
    monkeyface
    Colorado
    Did you miss this from my post? TLDR?
    "VSC, well, that can be a PITA. Yeah, I agree the VSC is too sensitive."
    Multiple points in one post are too much for you to handle?
  18. Jun 10, 2013 at 2:14 PM
    #38
    OZ-T
    Peter North
    British Columbia
    Had a chance to read this now
    Just shows your lack of reading comprehension , the OP is complaining of VSC overreaction that can be attributed to his lifting without re-calibrating the system , I responded to him with my experiences with the same situation
    You posted that the system is for retards and that you like it
    :notsure:
  19. Jun 10, 2013 at 2:15 PM
    #39
    OZ-T
    Peter North
    British Columbia
    Glad we agree
  20. Jun 10, 2013 at 2:18 PM
    #40
    teneighty
    Thanks captain obvious...
    Who blames only Toyota? Must have missed it.
