Traction control light and check engine light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MinnTruck, Jul 19, 2024.
  1. Jul 19, 2024 at 6:35 AM
    MinnTruck
    MinnTruck [OP] Member
    Tony
    09Tacoma2wd
    None
    Would 09 Tacoma 2wd have VSC? I have 2 buttons left of my steering wheel, 1) the traction control squiggly lines 2) RSCA off, which I have no idea what that is. My main problem is the traction control light and check engine light are on. The steering and driving are fine. It chugs when you start it up then runs fine. My pro friends code reader says #1 cylinder misfire, still after changing the coil pack and spark plug 3 times. Any help would be appreciated thanks, tony
  2. Jul 19, 2024 at 7:39 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yes VSC is standard on 09+
    RSCA stands for Roll Sensing Side Curtain Airbag, the switch turns the roll sensing part of the airbag system off for offroading.
    The Trac Off light will always accompany a CEL on Toyota with VSC, fix the CEL and the Trac Off light will go out.
    Stop throwing parts at it and at least do some basic tests, a relative compression test would be a good idea to start with for a misfire.
    TnShooter, MinnTruck[OP] and winkel like this.
  3. Jul 19, 2024 at 8:21 AM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
  4. Jul 24, 2024 at 2:58 PM
    MinnTruck
    Tony
    09Tacoma2wd
    None
    If there was an issue with one fuel injector, would that come up on the code reader as a misfire? I’m wondering because when the engine is cold and I start it, it cranks for 5 seconds before it starts. Someone had mentioned that on a YouTube video I watched recently. Any idea?
  5. Jul 24, 2024 at 3:43 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Possibly depending on how it failed but without testing anything would be a guess.
    First thing I'm doing when something comes in for a misfire is clear flood crank and see what the engine sounds like, if it sounds even with no skips then I'll move on to fuel and ignition. If it has a skip though then I'm checking compression.
  6. Jul 24, 2024 at 7:05 PM
    MinnTruck
    Tony
    09Tacoma2wd
    None
    Can a code reader check the compression?
  7. Jul 24, 2024 at 7:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Short answer is, No.
    Long answer is, Yes (kind of, sort of)
    But you're looking at a $1,000+ machine, wiring diagrams, and data recording.
    It's called a relative compression test. And it doesn't give you psi numbers.
  8. Jul 24, 2024 at 7:24 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No, you would need to use a gauge or scope.
    You can do a quick clear flood crank (hold the gas pedal to the floor and then crank, if it does happen to start release the gas pedal) and see how it sounds cranking. It should crank evenly, if it has a "skip" while cranking you have a compression issue.
    https://www.youtube.com/watch?v=bEmzih9MV7o
