Traction Control Light Came On
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CroResident, Nov 10, 2015.
  1. Nov 10, 2015 at 6:48 AM
    CroResident
    CroResident [OP] Well-Known Member
    Nick B
    Opelousas, Louisiana
    2015 4X4 DCSB
    6" Zone lift 35x12.50 Super Swampers
    i recently installed a 6" lift on my 2015 DCSB 4x4 SR5 and for some reason the traction control light is on. my traction control is disabled at all times because of this. i got the shop to hook up a diagnostics machine to it to see if they could figure it out and they couldnt. i also tried O'reillys and another shop in town and no success. anyone have any idea on what it could possibly be? thanks.
  2. Nov 10, 2015 at 8:25 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    You may have to go to the dealership to have it recalibrated.
  3. Nov 10, 2015 at 12:12 PM
    CroResident
    Nick B
    2015 4X4 DCSB
    man i hope not
  4. Nov 10, 2015 at 12:16 PM
    TNTramair
    TNTramair Well-Known Member
    2015 TRD OR SPORT
    Yaw rate sensor needs re-calibration.
  5. Nov 10, 2015 at 12:25 PM
    CroResident
    Nick B
    2015 4X4 DCSB
    i think i should be alright without the traction control. im just trying to get the light turned off for warranty purposes
  6. Nov 10, 2015 at 12:32 PM
    bowhunterRN
    bowhunterRN Well-Known Member
    Eric
    Greenville, NC
    14 MGM TRD sport DCLB 4x4
    I thought anything over a 3" lift would void all factory warranty? That's that my dealership told me
  7. Nov 10, 2015 at 1:42 PM
    CroResident
    Nick B
    2015 4X4 DCSB
    man i sure hope not haha i was told that my motor and transmission would still be warrantied
  8. Nov 10, 2015 at 4:11 PM
    lc_87
    lc_87 Active Member
    ohio
    2015 dclb 4x4
    steering wheel straight? had the same issue till the alignment shop corrected the steering wheel on my 2015. Cleared the code and been fine since.
  9. Nov 10, 2015 at 4:12 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    You might have stretched or pinched a wire when installing lift.
  10. Nov 10, 2015 at 7:56 PM
    CroResident
    Nick B
    2015 4X4 DCSB
    If this was the case, how would i know for sure?
  11. Nov 10, 2015 at 9:11 PM
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    I had to take mine to the dealership for diagnosis. My ABS wire got stretched when changing UCA's.
  12. Nov 11, 2015 at 3:23 AM
    CroResident
    Nick B
    2015 4X4 DCSB
    did you have to replace the wire?
  13. Nov 11, 2015 at 3:32 AM
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    They spliced and reconnected where it lost contact. Simple fix but dealership price.
  14. Nov 11, 2015 at 3:33 AM
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    I'll take pics tomorrow. It's late at night here.
  15. Nov 11, 2015 at 5:26 AM
    CroResident
    Nick B
    2015 4X4 DCSB
    ok cool. thanks man
  16. Nov 11, 2015 at 5:29 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Try disconnect the battery for few minutes.
  17. Nov 11, 2015 at 5:32 AM
    Vassily28
    A lot of sensors are involved in the traction control loop. Any dammage to one of them and the system is disabled. It could be something like a speed sensor.
  18. Nov 11, 2015 at 6:29 AM
    Pigpen
    Dan
    Northwest Montana
    Your sensors need to be recalibrated. Dealer should do this for free and it should take 5 minutes. Many people need this done even with much less lift and going to larger tires. This isn't a big deal.
  19. Nov 11, 2015 at 6:32 AM
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    i just had my slip indicator light re calibrated it was $50
    staring wheel was off center so system thought it was sliding
    i would just take it to the dealer it shouldn't be a huge issue
  20. Nov 11, 2015 at 6:49 AM
    TNTramair
    2015 TRD OR SPORT
    thats funny.
