TRACTION CONTROL LIGHT just came on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by babyduck, Jul 6, 2010.
  1. Jul 6, 2010 at 11:19 AM
    babyduck
    babyduck [OP] New Member
    ernie
    RI
    2006 tacoma stock
    MY Light (the one with the tire tread and the (i) over it just came on and not sure what I need to do to troubleshoot and turn it off. Checked my ODB codes and they are all clear. Pushed the button under the steering column and that made it blink, its now back solid. Any help is greatly appreciated.
    Ernie
  2. Jul 6, 2010 at 11:20 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    That's your low tire pressure sensor, not traction control. Check your tire pressures (don't forget spare).
  3. Jul 6, 2010 at 11:24 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yeahhh it sucks mines been on for like 6 months now
  4. Jul 6, 2010 at 11:42 AM
    babyduck
    ernie
    RI
    2006 tacoma stock
    thanks to all, must have missed it in the manual
  5. Jul 6, 2010 at 11:44 AM
    babyduck
    ernie
    RI
    2006 tacoma stock
    So what does the switch under the steering column do, reset the pressure reading in the computer once I get my pressures where I want them? I guess there must be a section in my manual but I didn't see it. I will check all pressures when I get home and go from there.
    thanks again to all for showing me how DUMB this old guy can be
  6. Jul 6, 2010 at 12:19 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Yea, ideally unless you changed something (new different size tires, running a new pressure, ect) you shouldn't have to push the reset (have to hold it in about 3 seconds to make the change).
    Once I even checked all the pressures, everything seemed fine... and discount tire found a nail in one. I'm not exactly sure how when I checked the tires it showed ok and the sensor found it but... it worked somehow lol. Dramatic temp changes can cause it too if you're riding the threshold of it's allowable pressure range to not trip the light.
  7. Jul 7, 2010 at 10:19 AM
    babyduck
    ernie
    RI
    2006 tacoma stock
    Thanks to all, appreciate all the info
    very helpful
  8. Jul 7, 2010 at 11:27 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    RTFM
    Not exactly sure how someone could "miss" it in the manual if you look for the meaning of the light.... :)
  9. Jul 7, 2010 at 11:29 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    The question has already been answered in a polite manner and the issue resolved.
