Traction control light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wthomps, Oct 14, 2022.
  1. Oct 14, 2022 at 3:42 PM
    Wthomps
    Wthomps [OP] Member
    2010 tacoma
    My light with the car light with the squiggly lines underneath it is on ! Any thoughts on what to do to get it off?
  2. Oct 14, 2022 at 3:43 PM
    tcjacado
    tcjacado Well-Known Member
    Most likely it's wheel speed sensor.
    wilcam47 likes this.
  3. Oct 14, 2022 at 3:47 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You need to scan the ABS module and see what code(s) it's setting.
    6 gearT444E, TnShooter and wilcam47 like this.
  4. Oct 14, 2022 at 3:53 PM
    tcjacado
    Usually the wheel /speed sensors do throw a code. You just need to make sure wiring is intact and then ohm out the sensor if wiring is all good.
