Traction control question.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by imagineer, Nov 4, 2020.
  1. Nov 4, 2020 at 11:31 AM
    imagineer
    imagineer [OP] Well-Known Member
    2017 TRD Off Road
    None yet
    This is probably a dumb question, but is the traction control light in the speedometer gauge supposed to illuminate on when you're in 2WD, and spin the tires? I'm not talking about doing burnouts, just a momentary slip of the rear wheels.
    Several times now, I've been running in 2WD and for various reasons, the rear tire slips a bit. Each time, I've only caught a glimpse of the yellow light on the dash, but I think its the traction control warning light.
    I was picking up a load of firewood and had the bed full. The exit of the dirt driveway had a short, but steep uphill and the rear wheels spun a little, and the traction light came on.
    Another time I was turning hard right, entering traffic on a wet road and the rear wheel(s) broke free a bit.
  2. Nov 4, 2020 at 11:32 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I believe that's an indicator it's in use.
    71tattooguy likes this.
  3. Nov 4, 2020 at 11:33 AM
    Joe Joe
    Joe Joe Well-Known Member
    Arthurdale, West Virginia
    2019 White OR DC MT
    ADM 2Lo Mod 3TPAM
    Yes it is just an indicator saying the tires were slipping. When I first got mine, it took me a few times to realize it only came on when the tires were slipping.
  4. Nov 4, 2020 at 11:33 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. It flashes very (too) quickly. I only catch it out of the corner of my eye because when it is slipping, I'm definitely paying attention to other things.
    71tattooguy and Junkhead like this.
  5. Nov 4, 2020 at 11:54 AM
    Tacoma_SR5Pro
    Tacoma_SR5Pro Well-Known Member
    '16 SR5 Pro
    I think I noticed I also get it when my tires rub and drive on it at full turn.
    Myles G and number1stunna like this.
  6. Nov 4, 2020 at 11:55 AM
    imagineer
    2017 TRD Off Road
    None yet
    Thanks all. i was concerned there was a sensor out of whack.
  7. Nov 4, 2020 at 11:58 AM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    It’ll usually make a faint kind of clicking noise as well. Or at least mine does.
  8. Nov 4, 2020 at 12:10 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    It's an indicator that the system is actively intervening and not that the wheels are slipping. Totally normal and proper.
    gudujarlson and tonered like this.
  9. Nov 4, 2020 at 12:41 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    What everyone already said.
    G.
  10. Nov 4, 2020 at 12:46 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Most definitely. I do normally hear the brakes chirping though, especially on the OR; albeit probably only when the wheels are spinning at different speeds.
    tonered[QUOTED] likes this.
  11. Nov 4, 2020 at 12:51 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I cant be the only who thinks a flashing light on the dash while you are sliding is a bad idea. Its toned down from my old rav4 where the light would flash along with a loud beeping alarm. But the last thing someone who is sliding needs is a flashing distraction on the dash.
    hiPSI likes this.
  12. Nov 4, 2020 at 12:51 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Agreed. For me, it is quiet unless the wheel spin is aggressive. Then, it gets louder.
  13. Nov 4, 2020 at 12:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I believe on our other cars with traction control, the light was steady and stayed on for half a beat after the system decided that life was fine. I don't distinctly recall since they were FWD turbos. On every drive, the first thing that I did was turn off the BS because it was less safe than dumping all torque and losing a second or so for it to build again. Esp when the slip was usually caused by a bot dot or paint line.
    Even on snow or ice, the one with stab control ran dangerously wider when the system was active.
    Flashing might not be the best implementation, but the Taco TRAC system is the only one that I actually have liked and don't turn off by default.
  14. Nov 4, 2020 at 1:01 PM
    5nahalf
    Erik
    Minnesota
    Go drive a 2007 rav4 awd in the snow... You will want to burn toyotas headquarters to the ground. It was by far the worst implementation of a traction control in the world, between beeping, flashing the lights, it also cut all power and applied the brakes till it got traction again.... oh and you couldnt turn it off either... there was a special procedure to turn it off.
    Here is how to turn it off on the old rav4
    Put the Rav in Park and start it
    1 .Put the handbrake on (not too hard, enough for the handbrake light to come on)
    2. Pump the foot brake twice (not hard) on the 2nd pump hold the foot brake on
    3. Release the handbrake & engage it twice (leaving it engaged)
    4. Then pump the footbrake twice
  15. Nov 4, 2020 at 1:04 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Geez! Don't forget to toss a pinch of salt over your shoulder and spit?
    Toyota and M-B (I think?) are somewhat infamous for having systems that are hard or impossible to turn off.
    On the rain dance side, to shut off the seat belt chime after a battery disconnect in our Forester, you have to insert and release the belt 20 times in 30sec. Friggin' engineers . . .
    5nahalf[QUOTED] likes this.
  16. Nov 4, 2020 at 1:05 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yeah, but consider this: It's pouring the rain and you are trying to pull out into traffic. You see an opening, stomp on it and you see the light flash. That tells me to back off the throttle a bit so it won't spin and retard the throttle. I can't hear it spin because it's pouring the rain.
    fuzzydoodle likes this.
  17. Nov 4, 2020 at 1:06 PM
    5nahalf
    Erik
    Minnesota
    I told myself before I got married that I would never buy a car with obd1 or newer just because of the ease of repairs. But then I got married and had kids.
  18. Nov 4, 2020 at 1:07 PM
    5nahalf
    Erik
    Minnesota
    But its already applying traction control when your spinning your tires. The truck should be actively fixing the spin instead of yelling at you that it is actively fixing the spin.
    hiPSI[QUOTED] likes this.
  19. Nov 4, 2020 at 1:12 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    With always dealing with carb problems, esp on non-adjustable ones, I was a big fan of early EFI. It was the proper balance of things to me. Unfortunately, that era is pretty slim. The prospect of ever getting my dream car in that time, the last gen air-cooled 911, is pretty much nil since I don't wanna deal with stuff of that vintage not even considering prices.
    For me, the real malaise era was EFI and electronic throttle bodies. Sure, things are too complex these days, but DI seems to be working nicely and is responsive enough to keep me happy. We'll see how the Taco lasts.
  20. Nov 4, 2020 at 1:14 PM
    5nahalf
    Erik
    Minnesota
    My dream was always a cyclone swapped astro van :)
