Traction control sensor problems with Lifted Tacoma 2007
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sltfrank, Apr 21, 2010.
  1. Apr 21, 2010 at 7:17 PM
    sltfrank
    sltfrank [OP] New Member
    salem or.
    07 tacoma double
    pro comp lift
    2007 Double Cab Tacoma TRD, I have a 6" PRO COMP lift kit with 33" tires. When turning from stop and in corners taken at recommended speeds, :confused:sometimes the roll over & traction control sensors go off and ABS breaks are applied. No computer codes and sensors are calibrated correctly. Would like to know if anyone knows of a Delete procedure for the sensors without removing relay to ABS brakes.
  2. Apr 21, 2010 at 8:02 PM
    Kdawwwg
    Kdawwwg Well-Known Member
    Ken
    Draper,Utah
    2010 Magnetic Grey DC Long Bed TRD Sport 4x4
    RCD 4.5" Lift ,Moded to 5.5",1.5 inch Toytec AAL Light Raceing UCA's, 285/70/17 Duratracks, Procomp 7028 Wheels 17X8.5x4.75, Leer XQ Shell,Keyless Entry,Bedrug, Kartec Front End Limiting Straps.
    have you done this
  3. Apr 21, 2010 at 11:45 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    X2 as above ^^^^^ reset the skid control ecu values .
    OZ
  4. Apr 22, 2010 at 7:43 PM
    sltfrank
    salem or.
    07 tacoma double
    pro comp lift
    thxs i try your suggestion.
  5. Apr 28, 2010 at 7:20 AM
    225nontypical
    225nontypical ????????????
    backwoods
    11 tundra DC TRD OffRoad
    bilstein 5100's weather tech floor mats katskinz leather heated seats
    anybody know what it would cost to have the dealer do this? i am having the same problem. i lifted my truck 3" and put 285/70/17 under it, not even a week ago and 3 times now the traction control has gone off on me!
    thanks for the info
  6. Apr 28, 2010 at 7:46 AM
    OZ-T
    Peter North
    British Columbia
    Mine was free , under warranty .
    OZ
  7. Apr 28, 2010 at 10:36 AM
    225nontypical
    backwoods
    i just wonder if they will cover it since i have a lift and bigger tires.
  8. Apr 28, 2010 at 10:40 AM
    phoneguy44
    phoneguy44 Well-Known Member
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    Nice DEER !!! :threadjacked:
  9. Apr 28, 2010 at 10:47 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I would have it done by the dealer, if something goes wrong its on them. VSC is a critical safety system; why mess around?
  10. Apr 28, 2010 at 11:14 AM
    225nontypical
    backwoods
    thanks it is Oregon state record "non typical velvet mule deer archery"
    :threadjacked::crapstorm: don't beat me up to bad for the hijack!
  11. Apr 28, 2010 at 11:16 AM
    225nontypical
    backwoods
    i am going to have the dealer do it i just made an appointment i just wonder if they will try to pull the whole "you lifted it and put bigger tires so now we are going to charge you a butt load of money cause we can thing"
  12. Apr 28, 2010 at 11:25 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    It should not cost any more than a stock tacoma. You're paying for labor. My guess is it would cost around $75.00. Right? I mean it's not going to take them more than an hour to recalibrate it.
  13. Apr 28, 2010 at 7:08 PM
    OZ-T
    Peter North
    British Columbia
    The tech scanned my truck , and then he zeroed the skid control ecu values with the truck hooked up to the computer . He then had to drive the truck for approx 10km , total time , under one hour .
    The key here is to zero in on your issue , and not have them dick around trying to diagnose the problem . If resetting the values fixes you up should be $100 tops .
    OZ
