Traction control turned itself off (and then back on) while driving in heavy rain.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 9mmMike, Mar 25, 2021.
  1. Mar 25, 2021 at 10:50 AM
    9mmMike
    9mmMike [OP] Well-Known Member
    Michael
    SE PA
    2019 TRD OR 4x4 DCLB - Cement
    Searched and could not find this but, no doubt, this cannot be unique.....
    Driving my 2019 DCLB automatic in extremely torrential rains yesterday. Hydroplaning occasionally but nothing too terrible although my pretty co-pilot thought it was a bit dicey. :)
    The "traction control off" light came on. I had no time to take my eyes off the road or fiddle with any dials or switches. After maybe a mile or so, the light went back out.
    Was my truck doing something normal/safety-related by doing this due to the rain or did something go wrong? I was thinking maybe a sensor got jarred from the heavy water hits or something. Really haven't a clue.
    Any ideas?
    Thanks!
  2. Mar 25, 2021 at 11:04 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Sensor error ... I would just keep an eye on it . If it does it again take to the dealer to check for errors .
    9mmMike[OP] likes this.
  3. Mar 25, 2021 at 11:05 AM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    in my experience, it could be 2 things. Not going to say it's for sure since I'm not seeing it, but when you loose grip or steering input doesn't match yaw sensor, it will flash. Another thing it could be is a malfunction of a wheel speed sensor. For me this occurred when a gasket on the sensor bound up when I removed and reinstalled the sensor which in turn increased the gap between the sensor and the wheel bearing. Simple fix. If water got into the harness, just unplug, apply dielectric grease to inhibit corrosion etc.
  4. Mar 25, 2021 at 11:07 AM
    Tacospike
    Two Trucks
    My light has come on for a few seconds then back off. Usually exiting a highway and hitting a area of water build up. The light turns off a second or two later after I pass the higher water area. Never had it stay on that long without me turning it off or holding it till it turns off
  5. Mar 25, 2021 at 11:08 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Normal. In heavy rain the sensor on the front can't read anything so it shuts off. Otherwise it would plow you into something. Put a piece of cardboard on it you'll get the same thing.
