Traction Control turns on randomly
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dannwil2000, Dec 29, 2021.
  1. Dec 29, 2021 at 12:50 PM
    dannwil2000
    dannwil2000 [OP] Member
    2017 Tacoma TRD Sport
    Hi, I drive a 2017 Tacoma TRD Sport and recently noticed that whenever I turn into a speed bump or driveway my traction control will go off randomly. The truck never used to do this so I tried to get it to do it again but it only does it sometimes. I checked all the sensors and they’re still good and I got the truck realigned recently and it still does it. I was wondering if you guys have any ideas. Thank you!
  2. Dec 29, 2021 at 1:23 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you're on the gas, the rear inside tire can easily slip enough to trigger it, esp in the wet and with tires that are getting older / worn.
  3. Dec 29, 2021 at 2:05 PM
    dannwil2000
    It’s happened in the wet and dry and I have brand new KO2’s that have only 5k miles on them. What really confuses me is that I turn off my traction control and it will still do it. I forgot to mention that originally too
  4. Dec 29, 2021 at 2:41 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Oh. That is weird, even as you have a 2017 with no TSS-P gizmos to calibrate.
    Still, you could do a Zero Point Calibration to see if that helps:
    https://www.tacomaworld.com/threads/how-to-reset-and-calibrate-your-vsc-computer-the-easy-way.467485
    doublethebass and Junkhead like this.
  5. Dec 29, 2021 at 2:47 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Or when tires are in the air and can accelerate freely.
  6. Dec 29, 2021 at 2:51 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That also.
    I tend to goof off a lot and get the inside rear pretty lightly loaded, so I see the TCS light flash pretty often.
  7. Dec 29, 2021 at 2:56 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    I would almost bet your getting enough variation in wheel speed that the wheel speed sensors are picking it up and triggering the TCS/VCS systems.
    I would start with a Zero Point Calibration.
    RSOTACO and Junkhead like this.
  8. Dec 29, 2021 at 3:10 PM
    dannwil2000
    Alright I’ll try out the Calibration to see if I can figure it out, thank you!
  9. Dec 29, 2021 at 3:14 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    FYI: Traction control button has to be held down to completely disable it. Pushing it once only enables the auto LSD.
  10. Dec 29, 2021 at 3:34 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Same same. I need to do something about my rear bumper stops haha.
  11. Dec 29, 2021 at 3:43 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I think I’m missing out. My taco has never sqawked the tires on pavement (dry or wet). I remember when I bought my 2016 and being the first automobile with traction control I was very surprised when I pushed the pedal to the metal on gravel and truck creeped forward peacefully. How gutless is this truck was my first thought. Later I learned how to disable the fun police.
    CherylJane and Junkhead like this.
  12. Dec 29, 2021 at 3:52 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I think it depends on the speed of the inputs. Like from a dead stop, there's time for the computer to stay on top of traction. But rolling ahead or adding roll (left and right) into the mix plus throttle position etc, it can't keep up.
  13. Dec 29, 2021 at 4:31 PM
    dannwil2000
    Thank you for all the input guys! I couldn’t really figure out how to do the Zero Point calibration so I’m gonna have my buddy who’s a mechanic look at it tomorrow
  14. Dec 29, 2021 at 4:34 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    When l first bought my old 2015 it kept kicking in traction control and ABS, turns out the had over 50 psi in the tires.
    Junkhead and dannwil2000[OP] like this.
  15. Dec 29, 2021 at 4:40 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    My fam hates how close it appears, but it is actually pretty far away.
    You're welcome!
  16. Dec 29, 2021 at 5:15 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I agree. There's probably a lot of travel but it seems so far.
    tonered[QUOTED] likes this.
  17. Dec 29, 2021 at 7:32 PM
    BetaTaco
    BetaTaco Built like a steakhouse, handles like a Bistro.
    Northern Virginia
    2016 SR5 V6 4X4 DCSB
    same shit as everyone else
    I'd start by checking your tire pressures. Some shops will just fill the tire to the max PSI it says on the sidewall. KO2s only come in LT sizes. So the max PSI depending on the tire's load index will be 50, 65, or 80 PSI. This should give you a general idea of where to be at tire pressure wise. If that's the issue.
    shakerhood likes this.
  18. Dec 29, 2021 at 7:34 PM
    dannwil2000
    I have all my tires set at 38-42 depending on the temp
    Junkhead likes this.
  19. Dec 29, 2021 at 8:10 PM
    shakerhood
    Southern Ohio
    They should only be around 29 or 30 as the Placard on the door and the Owners Manual recommend.
  20. Dec 29, 2021 at 8:27 PM
    dannwil2000
    38 is the oem psi I believe, I deflate them to 25 whenever I’m on the dirt lol
