Traction control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sig_07, Feb 22, 2016.
  1. Feb 22, 2016 at 4:21 AM
    Sig_07
    Sig_07 [OP] Member
    07 Tacoma Trd sr5
    Hey guys, and ladies
    I'm new to the forum and I have a few questions about my 07 Tacoma Trd sr5. I have been looking through the Manual and talking with a friend who owns a 11' Trd. He says that he has a traction control button and I don't have one. Also I don't see what the sr5 means? Can anyone in lighten me on this please
  2. Feb 22, 2016 at 5:12 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    SR5 is a trim level.
    It is not a TRD model.
    The trim levels are:
    SR/Base
    SR5
    TRD Sport
    TRD Off Road
    And Limited
  3. Feb 22, 2016 at 6:57 AM
    Sig_07
    Sig_07 [OP] Member
    07 Tacoma Trd sr5
    It has the Trd symbol on the side and a sr5 emblem on the back? Did someone add the sr5 emblems themselves? I bought it used
  4. Feb 22, 2016 at 6:57 AM
    Pigpen
    Dan
    Northwest Montana
  5. Feb 22, 2016 at 7:04 AM
    Sig_07
    Sig_07 [OP] Member
    07 Tacoma Trd sr5
    It has the 2h- 4h-4l and the rear dif lock as well as the towing package, so is just a sr5 4x4?
  6. Feb 22, 2016 at 7:06 AM
    Pigpen
    Dan
    Northwest Montana
    Sounds like they replaced the tailgate with one off an SR5 after the stock gate had an unfortunate incident.
    Edit: I'd remove the SR5 badge, since you actually have a TRD Offroad.
  7. Feb 22, 2016 at 7:15 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    2005-2010 trucks have the SR5 emblem on the tailgate for TRD-trim trucks. @Sig_07 you have a TRD Off Road model.
    Pigpen likes this.
  8. Feb 22, 2016 at 7:18 AM
    Sig_07
    Sig_07 [OP] Member
    07 Tacoma Trd sr5
    I do have the ax-doc converter in the back but the tailgate comment makes sense
  9. Feb 22, 2016 at 7:21 AM
    Sig_07
    Sig_07 [OP] Member
    07 Tacoma Trd sr5
    *ac-dc
  10. Feb 22, 2016 at 7:24 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    There is also the TRD Pro trim level
  11. Feb 22, 2016 at 8:55 AM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    Sorry Rock, I was speaking of more recently. Don't think we had the Limited all years either.
  12. Feb 22, 2016 at 9:41 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think that side airbag package was double cab only too.
  13. Feb 22, 2016 at 9:47 AM
    shakerhood
    Southern Ohio
    I still have the brochure from my 08 and it shows the only model available with optional side airbags as double cabs.
  14. Feb 22, 2016 at 9:57 AM
    shakerhood
    Southern Ohio
    I know I am getting off topic, but you guys forgot to list the X Runner above too.
  15. Feb 22, 2016 at 10:44 AM
    PackCon
    Connor
    :O I can't believe I forgot the most important one.
  16. Feb 22, 2016 at 3:06 PM
    KenLyns
    Belly of the Beast
    There were several more low-volume or regional trim levels, all of which are not relevant to OP's discussion:
    TX
    TX Pro
    TX Baja
    TSS
    XSP-X
    TRD Rugged Trail
    Trail Teams (Canada only)
    TRD Yamaha (Canada only)
