Traction Controls 2009-2015
Discussion in '2nd Gen. Tacomas (2005-2015)' started by David K, Jan 13, 2014.
  1. Jan 13, 2014 at 1:01 AM
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The Buttons do what? A discussion with simple answers to what the (up to) 10 drive modes some models have and how to use them.
    Limited Slip systems called TRAC, AUTO LSD, TRAC OFF and A-TRAC use engine output regulation and/or brake force to a non-traction (spinning) tire to transfer drive power to tires that have traction and can move you ahead.
    Some are automatic and others require a selection to have greater traction control or no traction control.
    The newer 2012+ term TRAC OFF in H4, is the same degree of control as what was called TRAC (in H4) in 2009. TRAC in 2012 became an engine output regulated traction control in H4, as it is in H2.
    2009-2011:
    Press Nothing...
    H2= TRAC (Limited Slip with Engine Output Regulation)
    H4= TRAC (Limited Slip without Engine Regulation, front and rear)
    L4= No Traction Control
    Quick Press (VSC OFF SWITCH) moving or stopped...
    H2= AUTO LSD (Limited Slip without Engine Output Regulation, VSC OFF to 30 mph)
    Press and Hold In 3-5 seconds (VSC OFF SWITCH) while stopped...
    H2= VSC OFF (No Traction Control)
    H4= VSC OFF (No Traction Control)
    Off Road TRD:
    Quick Press of RR Lock Switch= Rear differential Locker (L4 only on 4WD models)
    L4 Only: Quick Press of A-TRAC Switch= Front and Rear near-no slip traction control. A-TRAC works the front tires if speed drops below 3 mph, if the Rear Locker is also on.
    2012 + (chages in bold)
    Press Nothing...
    H4= TRAC (Limited Slip with Engine Output Regulation, front and rear)
    H4= TRAC OFF (Limited Slip without Engine Output Regulation)
    Off Road TRD:
    L4 Only: Quick Press of A-TRAC Switch= Front and Rear near-no slip traction control. A-TRAC works the front below 3 mph when the Rear Locker is also on.
    What should you use?
    Standard Mode until you lose traction, then quickly press the VSC OFF button to increase the power of your traction control (more engine RPM, stronger braking on the spinning tires).
    In L4 (Low Range) and your tires spin, press the A-TRAC button (Off Road TRD only) to nearly lock-up any spin. I always have A-TRAC on in L4... unless you need to spin the mud out of the tires.
    Emergency stuck if A-TRAC doesn't work in any situation, press the RR Lock button (works with or without A-TRAC working on the front tires). The rear locker connects both rear tires from inside the differential (0 spin). Turn off RR Locker, once you are unstuck.
    1) H2 TRAC
    2) H2 AUTO LSD (VSC OFF to 30 mph)
    3) H2 VSC OFF
    4) H4 TRAC
    5) H4 TRAC OFF
    6) H4 VSC OFF
    7) L4 VSC OFF
    8) L4 & A-TRAC
    9) L4 & Rear Locker
    10) L4 & Rear Locker & A-TRAC
  2. Jan 13, 2014 at 1:24 AM
    Black Pipe
    Black Pipe Well-Known Member
  3. Jan 13, 2014 at 4:04 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
  4. Jan 13, 2014 at 4:25 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    :rolleyes:
  5. Jan 13, 2014 at 6:42 AM
    Sledhauler
    Sledhauler Well-Known Member
    Derek
    MD
    13 DCSB TRD Sport 4X4
    I curious to what is happening in 4L on a sport model? No electronic help or all?
  6. Jan 13, 2014 at 7:20 AM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    open diff in 4lo on sport models...:jerkoff::jerkoff:
  7. Jan 13, 2014 at 7:37 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    and this is why you do the yellow wire mod...
    Or
    Just do the smart thing and buy the Off Road ... locker is so much better than simulated lsd's or an actual lsd.
  8. Jan 13, 2014 at 9:22 AM
    Luis1
    Luis1 Well-Known Member
    Alberta, CA
    2013 Tacoma DCLB TRD SPORT 4x4
    - OME 2.5 inch lift nitro charger with 886 coils in front and 2 inch lift OME nitro charger with heavy Dakar leaf pack - custom high clearance rear steel bumper with swing out made by Vertan Kustoms out of Alberta. Carts full size spare and 2 x 20L Jerry cans - Allpro Apex front bumper - Smittybilt 10000lbs winch w/ synthetic line - Dobinsons Snorkel - RA Motor sports roof rack and bed rack - 5 x 6inch Diode Dynamic light bars on roof - 2 x unknown brand ditch light pods - 5 x 285/70/17 BFG Ko2 - 5 x Black Rhino Stadium wheels - deep dish - 17x9.5 with - 18 offset - exhaust chop mod - rear seat delete - horrendous mpgs lol
    Thats all fine and dandy in the states where you can get an OR package in a double cab. Those such models are not available in Canada. Which ever asshat thought that was a great idea obviously doesnt know much. For me, however, an access cab is not feasable, so I had to go with the sport model, and its good to know we have at least some way of modding our trucks to overcome the stupid open diff only in 4L that toyota thought was a great idea.
  9. Jan 13, 2014 at 1:55 PM
    David K
    Why don't you guys in the Great White North make the calls to Toyota of Canada and demand a double cab Off Road TRD? A little 'revolution' against unfair practices can be good! Is buying one down here and importing it just out of the question? I hope for the best for all of you...
    I am on my second Double Cab Off Road 4x4 and my third Tacoma 4x4 Off Road. All three were good trucks, but this one is the best!
  10. Jan 24, 2014 at 8:01 AM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    Thanks, David! That's the best description yet. It's easy to understand and I might be able to remember all the modes now. :)
  11. Jan 24, 2014 at 9:06 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Thanks for the write up David!
  12. Jan 30, 2014 at 10:11 AM
    David K
    Glad it helps... I need to put things down 'on paper' to understand things better!
  13. Jan 30, 2014 at 11:51 AM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    I would have loved to have gotten an OR....but its not available in DC/LB.
  14. Jan 30, 2014 at 1:05 PM
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    Thanks for this info David
  15. Jan 30, 2014 at 1:06 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    They should just add a locker option to the Sport
  16. Jan 30, 2014 at 1:06 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  17. Jan 31, 2014 at 12:28 AM
    David K
    No, because the Sport is not an Off Road. :D
    What they should do is sell the Double Cab Off Road in Canada! ;)
    rarewolf likes this.
  18. Jan 31, 2014 at 7:33 AM
    OZ-T
    Peter North
    British Columbia
    Without getting into this whole Sport vs Offroad BS , seriously , Toyota should offer a locker as an option in the DCLB Sport
    Then they would have all the bases covered
  19. Jan 31, 2014 at 8:44 AM
    spencer44306
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    ^^^ this
  20. Jan 31, 2014 at 2:49 PM
    fyremanpat
    Pat
    757
    other than the locker whats the difference?
