Traction Controls 2009-2015
Discussion in '2nd Gen. Tacomas (2005-2015)' started by David K, Jan 13, 2014.
  1. Apr 20, 2014 at 11:56 AM
    #101
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I can't get a second gen because I cant afford one, but now I don't think I can because who could figure out this nonsense. I kid, but really they could pare all of this down into a simple one light one button system plus or minus a locker and prolly be fine. Hope when I get a second gen, marketing isn't controlling what the systems do.
  2. May 16, 2014 at 7:02 PM
    #102
    jafrisi
    jafrisi Well-Known Member
    Tucson, AZ
    14 Superwhite DCSB TRD OR
    Toytec bilstein 5100 lift w AAL. 2.5 front and 1.5 rear. KMC turbine wheels 4.5 bs, BFG KM3s 285/75/16
    Is there any danger/concern running this while daily driving?
    "Press and Hold In 3-5 seconds (VSC OFF SWITCH) while stopped...
    H2= VSC OFF (No Traction Control)"
  3. May 16, 2014 at 7:09 PM
    #103
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No
    I run with VSC OFF all the time
  4. May 16, 2014 at 7:40 PM
    #104
    bueller
    bueller Well-Known Member
    AZ
    I got a chance to try out some combinations last weekend and on one hill there's a steep section with deep holes that puts opposite corners in holes and the other front tire with traction had to step up onto a rock face. I had the locker on and A-TRAC off and even then I spun out. I hit the A-TRAC button and it started to spin and immediately locked up and pulled over the rock and on up the rest of the climb. I was pleasantly surprised at how well it worked.
    I also did the locker anytime mod and I must say it's a nice feature to have. In most cases, just hitting the locker button in 2wd will do the job with no need to engage 4wd. I also like being able to run in 4HI with the locker on in sand.
  5. May 18, 2014 at 3:04 PM
    #105
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    A-TRAC really is amazing.
  6. May 20, 2014 at 3:51 PM
    #106
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Welcome to the club! :D
  7. May 21, 2014 at 8:17 AM
    #107
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    Though OZ says no danger with it off....there is a situation where VSC can save your skin
    the 'moose test' (evasive maneuver test) has the best chance of success with all systems enabled VSC on. so, like in traffic on highway 45 mph or higher, it is generally best to leave it on, in case the unexpected happens. I have some real world pants-shitting happen to my 2013 tacoma at 70mph and VSC did it's dance clicking and grinding my ABS and throttle every which way, and even though I think my driver skill was key to keeping the rubber down, it recovered and stabilized much faster than I thought it could do
  8. May 21, 2014 at 9:02 AM
    #108
    OZ-T
    Peter North
    British Columbia
    It's never actually off
  9. May 21, 2014 at 10:03 AM
    #109
    NoSilverBullet
    NoSilverBullet N60 member
    Northern Canada
    2012 AC 2.7 MT 4wd
    Old Man Emu suspension: 884x coils, Dakar leaf pack, Nitrocharger Sport shocks. Cruisin Offroad bolt-on sliders. Relentless Fabrication aluminum front and mid skid plates + steel transfer case skid. SnugTop Hi-Liner "Sportsman" canopy. Hella Rallye 4000i Xenon (flood beam).
    That's a good point... A what point do you think the VSC and other electronic controls become ineffective (or dangerous?) when a truck is lifted? Installing larger tires would probably have a similar effect?
  10. May 21, 2014 at 12:10 PM
    #110
    OZ-T
    Peter North
    British Columbia
    There is also an ABS bypass switch mod so you can enable / disable all related systems in the fly
  11. May 21, 2014 at 11:57 PM
    #111
    OZ-T
    Peter North
    British Columbia
    Same as Landphil's method
  12. May 25, 2014 at 5:36 PM
    #112
    David K
    For anyone who does not lift their truck... anymore than what the 1" taller than stock 265/75-16 tires add... need not worry about the VSC. It only wigs out when you raise the truck with suspension mods.
  13. May 25, 2014 at 5:39 PM
    #113
    OZ-T
    Peter North
    British Columbia
    Not exactly true , mine started freaking out when I went to 265/70/17 Hankook MT's
  14. May 25, 2014 at 6:34 PM
    #114
    David K
    Wow? I wonder why mine didn't... How much taller is the 265/70-17 from what ever is stock on the Sports?
    The Off Road comes with 265/70-16 and I went to 265/75-16 which is approx. 1" taller in diameter (adds 1/2" of ground clearance). Not a thing changed with my VSC or anything else (and no rub on or off road with these tires).
  15. May 25, 2014 at 6:35 PM
    #115
    OZ-T
    Peter North
    British Columbia
    265/70/17 is the same size as 265/75/16
    The Sports come stock with 265/65/17 which is the same size as 265/70/16
  16. Dec 23, 2014 at 4:50 PM
    #116
    David K
    Maybe Santa Claus will read this?
  17. Jan 3, 2016 at 11:12 AM
    #117
    David K
    Never got a revised tech sheet for the 2012. Now, we have an all new 2016 Tacoma with Multi-terrain select and Crawl control... Looking forward to the details on how all that works.
    This thread could be re-named Traction Controls 2009-2015, however, I don't seem to be able to edit the title after so many years?
  18. Jan 3, 2016 at 1:50 PM
    #118
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Need pics of the dead spiders. :cool:
    DoorDing likes this.
  19. Jan 3, 2016 at 2:07 PM
    #119
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    pfft.....what it lacks in missing a front locker, it makes up for in being able to fit more stuff in the back.
  20. Jan 3, 2016 at 2:22 PM
    #120
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    *shiver*
