Traction Issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aubi1414, Dec 9, 2013.
  1. Dec 9, 2013 at 6:40 PM
    aubi1414
    aubi1414 [OP] War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    2010 Sport DCSB. So I tested out messing with my traction options on my truck and I thought everything was back to normal after holding down the traction buttons for a few seconds and then pressing for them to come back on, but now it seems like my traction control is off as my tires spin when I give it a lot of gas vs when it used to grip or grab like traction control was on. There are no lights on showing that anything is on or off as it used to look as well so I am slightly confused. Did I maybe blow a fuse and didn't know about it. I did install a DD radio a while back and it seems since then I have had this issue and only this problem??
  2. Dec 9, 2013 at 7:49 PM
    aubi1414
    Justin
    Pensacola, FL
    nobody ever had this happen?
  3. Dec 9, 2013 at 7:53 PM
    Joe D
    Joe D .
    I'm guessing you did shut the truck off and restart it and it's still slipping?
  4. Dec 9, 2013 at 7:54 PM
    aubi1414
    Justin
    Pensacola, FL
    oh most definitely its been doing it for a month or longer I just haven't mentioned it.
  5. Dec 9, 2013 at 7:59 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^ "as it used to look"... Please explain.
    Are you doing your test on wet pavement?
  6. Dec 9, 2013 at 8:02 PM
    aubi1414
    Justin
    Pensacola, FL
    Meaning on the gauge cluster there aren't any lights lit up. Besides when I turn on headlights or engage in 4 wheel drive.
  7. Dec 9, 2013 at 8:02 PM
    aubi1414
    Justin
    Pensacola, FL
    Yes its generally when its raining
  8. Dec 9, 2013 at 8:10 PM
    Joe D
    Joe D .
    Don't know man. I know mine needs shut off then tunred back on for some functions to reset. You could try Autozone for a code read...it's free.
  9. Dec 9, 2013 at 8:10 PM
    OffroadToy
    What lights do you expect to be lit up? During normal driving there aren't any. When the pavement is wet it's slick... causes increased tire spin with during heavy acceleration with these light back-end trucks.
  10. Dec 9, 2013 at 8:12 PM
    aubi1414
    Justin
    Pensacola, FL
    I thought the traction control would kick in if my tires were slipping while wet? Is this not on all the time unless you turn it off?
  11. Dec 9, 2013 at 8:18 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Excess wheel spin should temporarily flash the VSC light
  12. Dec 9, 2013 at 8:24 PM
    aubi1414
    Justin
    Pensacola, FL
    This is not happening at all. It is like I have no traction control. Where is the fuse for this?
  13. Dec 9, 2013 at 8:36 PM
    OZ-T
    Peter North
    British Columbia
    There is a fuse layout in your manual
  14. Dec 10, 2013 at 5:24 AM
    aubi1414
    Justin
    Pensacola, FL
    So this is normal from what yall are saying?
  15. Dec 10, 2013 at 5:48 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    If you leave hard on wet roads, expect some tire spin. If you floor it and try to keep them spinning it should activate but a little spin is ok. If you are going around a corner or whatever and try to kick out the ass end I bet it will beep at you cut power.
  16. Dec 10, 2013 at 7:52 AM
    aubi1414
    Justin
    Pensacola, FL
    I just tested this in the a.m. being it is raining again and it spun without blinking again and messed with the VSC button some more then tried again and got the blinking VSC its working correct and thank you all for your input :)
  17. Dec 10, 2013 at 7:58 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    :popcorn:
  18. Dec 10, 2013 at 11:56 AM
    OffroadToy
    Just tested mine on snow. When spinning the rear tires (2WD) i can't get the VSC to kick in while going in a straight line. The minute i get into a turn with the tires spinning the VSC kicks in. Loseing sideways traction triggers it... (slide vs spin.)
  19. Dec 10, 2013 at 12:20 PM
    aubi1414
    Justin
    Pensacola, FL
    AHHHHH that makes more sense now because when I have been spinning lately its on an incline while wet giving it a good bit up gas going straight. I tried this morning and I slide a bit when the VSC light blinked on. Makes complete sense now. Thanks
  20. Dec 10, 2013 at 12:50 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This thread reminds me how happy I am to not have an electronic nanny living within the truck's computer :)
