Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Nov 27, 2021 at 6:08 PM
    #5801
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    Nice Score on the HF trailer, I sold mine for what I paid five years earlier. It's the perfect size for a lawn tractor or a Home depot run behind the truck.
    Agree with Tormacher on the hinges being the weak grounding point. I ran an extra ground wire to all the lights and had no more problems.
  2. Nov 27, 2021 at 8:21 PM
    #5802
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Hinge on my trailer wasn't just weak for grounding, it was physically weak. As in broken through on one side and almost through on the other. The latch was holding the tongue on more than the hinges were. Had to do a field weld just to get it home. Could see where it had been pulled hard and deformed the hinges before they gave out. But, yes, my 4Runner didn't like the lights being grounded to trailer. I had to run a new ground wire from the plug to every light.
    Got my mower running. Battery took a charge and tested good so that saved me about $180 not buying one yet.
    Pulled safety switches out of the seat and brake pedal. Neither felt smooth when pressing my hand. Sprayed them with electronical cleaner and cycled by hand until they felt better. Started right up after I plugged those back in.
    Still not sure about the PTO. Bogged down first time engaged. But after running a for a while, I could turn PTO off and on without it bogging the engine at all. Cutting through some thick stuff had plenty of power. It's like something sticks after it sits for a while. I'm going to try hosing it all off good and do the normal tune-up stuff (fuel filter, plugs, air filter), run a can of some fuel system cleaner through, and check/grease the spindles on the deck.
  3. Nov 28, 2021 at 4:20 PM
    #5803
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Got the exterior of the shop 100% finished and sealed up Saturday. Moved inside today, threw 100’ of romex and installed new lights. The short days this time of year make you appreciate good lighting
    Delta09, koditten, Hunterdc1 and 6 others like this.
  4. Nov 28, 2021 at 6:17 PM
    #5804
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    :101010:
    koditten, Hunterdc1 and RustyGreen like this.
  5. Nov 28, 2021 at 6:32 PM
    #5805
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Space envy! :jellydance::jellydance::jellydance:
    Enjoy the new shop! :thumbsup:
    six5crèéd[OP] and Hunterdc1 like this.
  6. Nov 28, 2021 at 7:13 PM
    #5806
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Got all the wiring replaced on the trailer today. I did a new harness inside spiral loom, soldered or butt connected with heat shrink over the butts. Eyelet grounds on all lights. The lights are LEDs and all work great.
    I also tightened all bolts on it. Still need to grease the hubs and check bearing preload.
    20211128_124545_compress8.jpg 20211128_124715_compress64.jpg 20211128_125217_compress28.jpg
  7. Nov 29, 2021 at 11:13 AM
    #5807
    bigmw
    bigmw Not-So-Well-Known Member
    Northeastern Ontario
    2016 Blue DCSB Sport 4x4, manual transmission
    Bunch of different mods
    Hey TW,
    I would like to know what this thing is worth:
    McCormick Deering, circa 1909
    Motor is not seized up (it turns over with the crank), but it hasn't ran in a decade (or 2 or 3).
    Comes with a potato harvesting attachment
  8. Nov 29, 2021 at 11:23 AM
    #5808
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Personally, I wouldn't give more than $500 (that's on the high end) for it, it would need a lot of work to get going if it's been sitting there that long.
  9. Nov 29, 2021 at 1:52 PM
    #5809
    RustyGreen
    sleeping in a chair
    Pavement Princess
    That hub greasing set up is slick!
    six5crèéd[OP] and koditten like this.
  10. Nov 29, 2021 at 1:59 PM
    #5810
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Shane is probably on track with $500, it is worth scrap weight plus the cool project factor I guess.
    I'm the wrong guy to ask about sound financial decisions when it comes to machines, I buy stuff so it won't get scrapped. :anonymous:
    That said, if it is complete it sure would be a nice project to hear running again.
    Let us know.
  11. Nov 29, 2021 at 2:38 PM
    #5811
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Deck sprucing up time. Absolutely nothing wrong with this deck except it looks like ass! I gotta clean up the surface rust and re-bush the pin anchors.
    These 400lbs decks are easy to deal with when you work smart, not hard.PXL_20211129_201650184.jpg PXL_20211129_194557661.jpg PXL_20211129_195300676.jpg
  12. Nov 30, 2021 at 12:52 PM
    #5812
    koditten
    Kirk
    Central Michigan
    Deck is stripped of assessories, needle scaled and wire wheeled.
    I need to retract a previous statement. This deck did have something wrong with it. The spindle pulleys had cracks in them. Would have never seen them if hadn't taken it apart.
    I'll do some welding on it, then wipe it down with paint prep. Then paint.PXL_20211129_201650184.jpg PXL_20211130_204410156.jpg PXL_20211130_204414157.jpg PXL_20211130_204306210.jpg PXL_20211130_204311160.jpg
  13. Nov 30, 2021 at 3:09 PM
    #5813
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    That is a beefy freakin deck! I couldn't even compare that thing to the deck on my JD mower.
    six5crèéd[OP] and RustyGreen like this.
  14. Nov 30, 2021 at 3:26 PM
    #5814
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    So the spindle pulleys - you just replace those?
  15. Nov 30, 2021 at 3:40 PM
    #5815
    koditten
    Kirk
    Central Michigan
    The pulleys are fine. It's the hub part that gets swapped out.
  16. Nov 30, 2021 at 3:49 PM
    #5816
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Makes sense and basically what I meant. Thanks
  17. Nov 30, 2021 at 4:10 PM
    #5817
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Are cracked hubs a common thing to find on the commercial duty mowers?
    six5crèéd[OP] likes this.
  18. Nov 30, 2021 at 5:41 PM
    #5818
    koditten
    Kirk
    Central Michigan
    I'm guessing yes.
    This is the 4th I've found. Hit a solid rock and you will cause this trauma.
  19. Nov 30, 2021 at 5:57 PM
    #5819
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Or he might find someone willing to just use it for lawn decor which looks like what he's been using it for.
    Maybe check local orchards, nurseries, or garden centers in your area. Talk to the owners. I see that sort of decor at those types of places often enough. Or if you have "learning farms" or agriculture schools, they may have an interest for the historical aspect.
  20. Nov 30, 2021 at 6:05 PM
    #5820
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Me and rocks have some history...
