Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    46.4%
  2. After
    57.1%
  3. Neither
    14.3%
  4. I weed whack while someone else mows
    7.1%
Multiple votes are allowed.
  1. Oct 26, 2020 at 1:09 PM
    #1861
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Snow! Sheesh... you’d think the fire across the way would melt it.... ;-)
    six5crèéd[OP] likes this.
  2. Oct 26, 2020 at 1:17 PM
    #1862
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    You guys had snow already?
    :jellydance:
    We were about 2 degrees away from it this morning, but we just got 34 degree rain instead. :censored:
  3. Oct 26, 2020 at 1:28 PM
    #1863
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Had better than a foot yesterday and last night.
    Hoping it helps extinguish the fires.
    I'd rather have falling snow than any more falling ash.
  4. Oct 26, 2020 at 1:29 PM
    #1864
    Noelie84
    Noel
    Wales, Maine
    Understandable.
  5. Oct 26, 2020 at 1:31 PM
    #1865
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Yes agreed, stay safe and fun in the snow!
  6. Oct 26, 2020 at 1:44 PM
    #1866
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    WTF are you hooligans doing with that diesel additive?
    I had to get checker approval to buy it at the wallymart.
    I'm going to quit doing meth if that's what you're making it with.
  7. Oct 26, 2020 at 1:59 PM
    #1867
    Noelie84
    Noel
    Wales, Maine
    Hey, the only way I inject it is with a high-pressure fuel pump.
    Kids these days...
  8. Oct 26, 2020 at 5:49 PM
    #1868
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Any of you plow a gravel drive?
    My plow has 4-5" diameter spring loaded feet on it. I imagine they're great for pavement or concrete, but they're too easy to dig into gravel or RAP.
    I'm thinking I need like 12" or bigger saucers. Something that would "ski" on top of the gravel and not dig in.
    The flat access road is fine, just set the blade height and go but my driveway is sloped and the tractor pitches up and down making it too easy to destroy the RAP.
    Ideal would be fabricating something impermanent that I could attach to the existing feet.
    Any experience/ideas?
  9. Oct 27, 2020 at 4:26 AM
    #1869
    Noelie84
    Noel
    Wales, Maine
    One trick is to take a PVC pipe and cut a slice in it lengthwise and slip it on over the cutting edge. Not very practical for a road-going truck (since you'd have to install/remove it at every driveway), but would work fine for a tractor that doesn't leave your property.
    Personally, I plow my gravel driveway with a 1000lb v-plow, no shoes, and I just float it a bit until the ground freezes up. After that it's pretty much a non-issue, but I do always end up with a small pile of gravel at the far end of the driveway once the snow melts in the spring.
  10. Oct 27, 2020 at 6:30 AM
    #1870
    Noelie84
    Noel
    Wales, Maine
  11. Oct 27, 2020 at 8:48 AM
    #1871
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    first one is ABS. That might be less likely to shatter than PVC....
    I wonder about using a steel pipe. I have some 2-5/8" drill stem. Might give that a shot.
    T-yoda and six5crèéd[OP] like this.
  12. Oct 27, 2020 at 9:07 AM
    #1872
    Noelie84
    Noel
    Wales, Maine
    Yeah, I just googled 'PVC pipe on plow' and grabbed a couple of images to illustrate the concept.
  13. Oct 27, 2020 at 9:59 AM
    #1873
    zimmmtaco
    zimmmtaco Better than it was before it got like it is
    Northwestern PA
    15 DCSB Blue Ribbon Met 4x4 OR, 6MT
    TRD Pro susp kit 265/75R16 BFG K02's Husky Floormats Vent visors Hella 500 on custom mount
    I use 3" schedule 40 steel pipe when i make mine... also use some flat stock welded to each end to attach it to the plow so it doesn't come off when backdragging
    1st one lasted about 7 years on a Fisher 8' plow, and easily pays for itself in the time not spent raking rocks out of the yard......
    Hardest part is slitting the pipe to accept the plow - usually use 4 1/2" grinder with cutting wheels, as I don't have an 8' straight edge
  14. Oct 27, 2020 at 3:29 PM
    #1874
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    What does all do when it’s cold outside? Some Hibernate? Some work on projects for the spring as in maintaining there tractors and way not? Some don’t even go into the garage until after the new year!??
    Once the grass stops growing and I get caught up on cleaning my mower and garage up for the upcoming snow season. I seem to hibernate until about January/February... I get the need to “find” something to project on. No heat in the garage so I gotta pick the warmer days to do this.
  15. Oct 27, 2020 at 3:53 PM
    #1875
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Deer hunt :D
    T-yoda[QUOTED] likes this.
  16. Oct 27, 2020 at 5:45 PM
    #1876
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I don't have heat either but I figured it out last year. Put a couple electric space heaters out there first thing in the morning while I had coffee and breakfast then went out and walked around the garage with my weed burner running on jet burner waving it all around for about 3 rounds.
    Knocked the chill off and the space heaters maintained it.
  17. Oct 28, 2020 at 5:41 AM
    #1877
    Noelie84
    Noel
    Wales, Maine
    Well, I use mine all winter. I use it to shuttle firewood between the woodshed and the house, because it takes a lot fewer trips to get a week's worth of wood in than with a wheelbarrow. Plus once the snowbanks start getting long after a few storms I use it to push them up/back so I don't run out of space.
    And I hire out to do the same thing for other people. Seems like people are always surprised how fast their driveways fill up after a couple of decent storms.
  18. Oct 30, 2020 at 2:50 PM
    #1878
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Seems as if the cold weather is slowing the tractoring thread up....hope all is well! Enjoy the Halloween weekend
    six5crèéd[OP] and Bigdaddy4760 like this.
  19. Oct 30, 2020 at 3:09 PM
    #1879
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    I use a kubota with 60” bucket back drag then just push it into a pile. Plow was slower and got gravel all over.
  20. Oct 30, 2020 at 4:48 PM
    #1880
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Here in Alabama without power and no generators left. I have an inverter I’d like to run my fireplace insert fans, charge some stuff etc. nothing too demanding. Would prefer to run it off of my kubota l2501 instead of the truck. Any issues with leaving the tractor idling for hours? What RPM would you guys suggest? Any help would be greatly appreciated.
