Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Jan 2, 2021 at 11:52 AM
    #2301
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    I went to the John Deere store about 2 months ago and they had all kinds of big shit torn apart... combine... 8wheeler and something a tad smaller separated in the middle!! I was like... :eek:
  2. Jan 2, 2021 at 12:08 PM
    #2302
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Yeah. We’re slow(ish) right now with big AG. But I’ll have to share some pictures from our larger AG stores. Pretty wild stuff.
  3. Jan 3, 2021 at 12:21 PM
    #2303
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    The XT3 is having the same symptoms, again. I barely ran it after the fluid and filter change. I changed out the aftermarket filter to the Cub and topped off the fluid...same thing, although it seemed fine initially. I noticed that I was able to roll the tractor regardless of the bypass valve position, so I took that out, cleaned and inspected and no change. I wonder if a relief valve isn't stuck partially open or if there is air trapped in the system. Really disappointed with this tractor with 188 hours on it and 3 months out of warranty. Any ideas or input would be appreciated. FYI this is my first time working on a hydro system.
    T-yoda and six5crèéd[OP] like this.
  4. Jan 3, 2021 at 12:34 PM
    #2304
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Take a good hard look at Hydro-Gear's service manual and follow the troubleshooting and repair guide. I haven't had problems with any of my 3 BDUs yet so I'd just be guessing.
    https://hydro-gear.com/32a590b0ae_sites/hydro-gear.com/files/BLN-50327_P6.pdf
  5. Jan 3, 2021 at 3:12 PM
    #2305
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
  6. Jan 3, 2021 at 5:08 PM
    #2306
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    It doesn’t show it in any of the images, but the front uprights have chain slots to chain the top to the upper bucket. Lift heavy without the upper support and you’ll peel the bottom of the bucket out.
  7. Jan 3, 2021 at 5:13 PM
    #2307
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Gotcha... just a thought as this would help lift some logs onto the trailer
    six5crèéd[OP] likes this.
  8. Jan 4, 2021 at 6:56 AM
    #2308
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    My father has a set, uses them on his Kubota L2850. Just be careful as mentioned, too much weight and you'll bend the cutting edge. You have more support from the outer edges where the bucket's sides tie in if you have wood long enough to set them that wide.
  9. Jan 4, 2021 at 7:06 PM
    #2309
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    Brought home the blower for my new to me tractor later this week.
    67D5EC8A-2026-44B9-945B-7189CE05ABAC.jpg 062A59B5-888B-4E48-8323-96B785FA49FE.jpg
    Bigdaddy4760, Bushed, shaeff and 5 others like this.
  10. Jan 5, 2021 at 8:19 AM
    #2310
    Blkvoodoo
    Kevin
    Near Clayton NC
    This happened a lot faster than expected 333FF8C7-920C-4FE7-A99B-76BF83BCCA97.jpg
  11. Jan 5, 2021 at 8:20 AM
    #2311
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Are you going to load them or run them dry?
    Bigdaddy4760 and T-yoda like this.
  12. Jan 5, 2021 at 8:21 AM
    #2312
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Meanwhile, I'm still waiting on a pair of dinky little u-joints for my ATV that I ordered at Thanksgiving :laugh:
  13. Jan 5, 2021 at 8:59 AM
    #2313
    Blkvoodoo
    Kevin
    Near Clayton NC
    Current tires are not loaded and I haven’t really had issues with what I do with the machine. Probably stay dry unless I need to make changes
  14. Jan 5, 2021 at 12:25 PM
    #2314
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Went logging and split 2 cords of wood... tell me that’s not a full days of work... I’m beat
  15. Jan 5, 2021 at 1:04 PM
    #2315
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    On this episode of creek loggers......:D
    :thumbsup:
  16. Jan 5, 2021 at 1:41 PM
    #2316
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Funny watching bro joe fall down on wet wood!! See I only drank 5... he’s up a couple more :drunk:
  17. Jan 5, 2021 at 7:58 PM
    #2317
    Tractorman
    Tractorman Just A Dumb Farmer
    Stupid
    Misery
    2015 DCSB / MGM
  18. Jan 7, 2021 at 8:17 AM
    #2318
    jester156
    Cumberland, RI
    New to me tractor day.
    2018 JD 3046R, 385A backhoe. 299 hours. 18’ Trailer included. Time to dig holes and fill them in.
  19. Jan 7, 2021 at 8:18 AM
    #2319
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Nice! I like the thumb on the backhoe.
  20. Jan 7, 2021 at 8:20 AM
    #2320
    jester156
    Cumberland, RI
    Should come in handy. Now to learn how to use it.
