Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Apr 12, 2021 at 6:11 AM
    #3041
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    I’ve been here 11 years and haven’t had one done yet..... maybe this spring. nothing goes down the drain but minor for scraps and all produce is composted.
  2. Apr 12, 2021 at 6:21 AM
    #3042
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    We had ours done when we first bought the house, and that'll be 9 years this fall. It's just the two of us and we don't send anything unnatural down the drains, but the leach bed is the original to the house (built in the late 70's), so where it's an older system I'd rather be safe than sorry.
  3. Apr 12, 2021 at 7:15 AM
    #3043
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Nice!
  4. Apr 12, 2021 at 7:53 AM
    #3044
    ralfnjan
    ralfnjan Well-Known Member
    Ok, maybe a stupid self moment. I used my JD1830 to split wood last fall. It was with a 32 ton Splitfire splitter. The transaxle got too hot to touch (the moments) after several hours working. After that the hydraulics started to shudder when raising the loader and/or 3pt hitch.
    On the weekend I changed the fluid, the transmission filter element and cleaned the intake screen. The screen was 30% covered in crap. I thought after the cleaning and new fluid things would be back to normal...but the shuddering is worse than before! Should I be concerned about the hydraulic pump, clean the screen again, not worry about it on a 50 year old tractor? The screen deposits looked like crunchy carbon deposits. Maybe the cooking loosened up hard deposits in the system?
    Any thoughts?
  5. Apr 12, 2021 at 8:16 AM
    #3045
    Noelie84
    Noel
    Wales, Maine
    Hopefully they're not crunchy 'burnt seal' pieces. That would explain the shuddering, although not necessarily that it got worse, unless it's shuddering because there's air in the system
  6. Apr 12, 2021 at 10:46 AM
    #3046
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    After cutting my 5 acres. Think it’s time to swap the oem blades for some gator blades. Love this mower more every time I get on it. Sure smokes the hell out of my old exmark walk behind.
  7. Apr 12, 2021 at 10:53 AM
    #3047
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I've always heard gator blades are more for mulching and don't cut grass very good because they don't create enough vacuum to suck and hold the grass up. Not sure if it's true or not.
    RustyGreen and T-yoda like this.
  8. Apr 12, 2021 at 10:55 AM
    #3048
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    My Frankenmower has an 18 HP Briggs Vanguard and I never buy the Briggs filters for it. I used a PL14476 this time. $6, bigger, and probably better than an OEM filter.
  9. Apr 12, 2021 at 11:10 AM
    #3049
    Babybluetaco
    Austin
    09 5 lug
    I had them on my exmark and they performed well. We shall see. There like 50$ for all 3 so not like I’ll be out much if they do suck.
  10. Apr 12, 2021 at 12:16 PM
    #3050
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    I'm having my "stuff" sucked out of our tanks on Thursday. :poking::crapstorm:
  11. Apr 12, 2021 at 12:57 PM
    #3051
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    i have no idea if i have gator blades, but iknow they are mulchers and I'll never be without them. They just pulverize the leaves and grass.
  12. Apr 12, 2021 at 3:22 PM
    #3052
    jester156
    Cumberland, RI
    I’ve had a set on my JD 2320 with a 62” deck. They performed much better than the stock. I’d expect great things out of a zero turn which has a higher blade speed by design.
  13. Apr 12, 2021 at 3:23 PM
    #3053
    Babybluetaco
    Austin
    09 5 lug
    Will report back and let you guys know how they perform
  14. Apr 12, 2021 at 5:40 PM
    #3054
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    I use Gator blades on my Kubota, they do pretty well, still need to have the deflector up when in tall stuff, a second pass usually takes care of unmulched clumps.
  15. Apr 12, 2021 at 5:41 PM
    #3055
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I may get a set for the Hustler and see what happens. If they don’t do good in grass I can always use them this fall when I put the vacuum back on.
    T-yoda and RustyGreen like this.
  16. Apr 12, 2021 at 5:43 PM
    #3056
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Not sure why I didn’t do this before now. My quick attach is always fighting each other. The right side always comes out first. Not anymore :D
  17. Apr 12, 2021 at 6:00 PM
    #3057
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Already had a bees nest started on both sides under the fender where the hand holes are. Every year there is one. They both had one bee each so far.
  18. Apr 12, 2021 at 6:57 PM
    #3058
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Stinkin paper wasp.
  19. Apr 13, 2021 at 4:34 AM
    #3059
    Noelie84
    Noel
    Wales, Maine
    Well that would have made for quite a surprise the first time you used the hand grip :laugh:
  20. Apr 13, 2021 at 4:38 AM
    #3060
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Last year I got on and off the tractor and used the hand hole, then noticed a wasp nest there with about 6-8 wasp on it. Lucky I didn't get stung!!!
