Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    44.8%
  2. After
    58.6%
  3. Neither
    13.8%
  4. I weed whack while someone else mows
    6.9%
Multiple votes are allowed.
  1. May 5, 2021 at 7:18 PM
    #3461
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Orange It.
    Scott
    San Antonio, Tx
    08 Toy-yo-duh TACO TRD
    100% sand here, I will have grab a picture of some old blades, by the time I'm done with some of the blade sets they might be 1.25" wide, lol.
    If I cut at 2.5in height, I might get 30 hours out a set of blades. I use sand blades 80% of the time till Fall and leaves, sand blades are flat, double sided with cutting edges.
  2. May 6, 2021 at 7:11 AM
    #3462
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Hummmmm, 500.00
    Woods box blade, new never used. Seems like a good deal. Anyone have a Woods box blade?
  3. May 6, 2021 at 7:13 AM
    #3463
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I have a Bush Hog brand, looks about the same. Mine is 7' and I paid $955.56 for it. I know that is a specific price, had it in my notes on my phone :D
  4. May 6, 2021 at 7:17 AM
    #3464
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    I have a box blade, but not a Woods.
    My tines are individually held in by pins. Trying to figure that one out from the picture. Looks like maybe there's a plate that runs behind all of them and holds them in on their notches?
    Seems like a high stress point if you use the tines to dig much. I wonder if that system would hold up as well.
  5. May 6, 2021 at 7:19 AM
    #3465
    ColoradoTJ
    Colorado
    I definitely couldn’t run a 7’ box blade with the shanks down. :rofl:
    That’s a good price on a 7’.
  6. May 6, 2021 at 7:20 AM
    #3466
    ColoradoTJ
    Colorado
    You have some good points. Let me see if I can find some information out on this particular model.
    RustyGreen and six5crèéd[OP] like this.
  7. May 6, 2021 at 7:30 AM
    #3467
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I think that Woods has a bar that holds two shanks on each end then the lynch pin holds the bar, not sure what holds the middle one in.
    RustyGreen likes this.
  8. May 6, 2021 at 7:30 AM
    #3468
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I got it from a dealer who posted it in c-list, I think they had it for a while and just wanted it gone.
  9. May 6, 2021 at 7:34 AM
    #3469
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Here’s the only picture I can find of it from 5 years ago. It only has 6 shanks, they have a pin through each one.
  10. May 6, 2021 at 7:38 AM
    #3470
    ColoradoTJ
    Colorado
    Guess I need to see how these shanks are held into place.
  11. May 6, 2021 at 8:19 AM
    #3471
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    $500 does seem like a decent deal. Most of what I've done with my box scraper has been with the tines fully raised so depending on your use, it may not matter much.
  12. May 6, 2021 at 8:22 AM
    #3472
    ColoradoTJ
    Colorado
    Operation widening/drive over fenders going on right meow.
    Panther approves.
  13. May 6, 2021 at 10:03 AM
    #3473
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Looking good!
  14. May 6, 2021 at 10:04 AM
    #3474
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    @T-yoda I had to go to the local hardware store (small one) and get a couple of grinding bits, they were in the welding section and I found this there. It’s called a "tip drill set" but will be perfect for carb jets. All the bits are inside the handle, it was $14.
  15. May 6, 2021 at 12:27 PM
    #3475
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    I have an older Woods 48” I bought used for $300. Shanks are held individual.
    A1B9FE60-3460-4E86-97DE-7EDA971AAE6E.jpg C35329E2-5E12-4201-924F-06A39A8DBA3F.jpg
  16. May 6, 2021 at 12:58 PM
    #3476
    Zeke588
    Zeke588 Well-Known Member
    Zeke
    Billings, Mt
    Bluerunner
    03 V8 limited
    It’s aerating season for the golf courses.75EEE477-1663-4486-B363-A3EB80EB75C2.jpg
  17. May 6, 2021 at 1:11 PM
    #3477
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Don't they have a pin behind the ripper to hold it forward into the height setting slot at the front of the ripper?
  18. May 6, 2021 at 1:41 PM
    #3478
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Sweet! I was just at home depot gathering up lawn mower parts to finish another mower.... in and out I was though... hang around to long and you get to see to much of stuff you don’t need or wanna see :anonymous:
  19. May 6, 2021 at 1:51 PM
    #3479
    ColoradoTJ
    Colorado
    I think so, from some of the videos I’ve watched.
  20. May 6, 2021 at 2:23 PM
    #3480
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Much needed accessory for the lift table. Air wrench powered winch for dead zero turns. Those things suck to push even with the bypasses open.PXL_20210506_202323281.jpg
    shaeff, T-yoda, RustyGreen and 3 others like this.
