Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    46.7%
  2. After
    56.7%
  3. Neither
    13.3%
  4. I weed whack while someone else mows
    6.7%
Multiple votes are allowed.
  1. Feb 8, 2024 at 4:21 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I want to know does 1 of those signs say slow children playing?:rofl:
  2. Feb 8, 2024 at 6:43 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Haha no, one says you are on video and the other says there is a security system. I need one more that says no solicitation.
  3. Feb 8, 2024 at 11:18 AM
    ralfnjan
    ralfnjan Well-Known Member
    My neighbour got "surface treatment" done...didn't turn out like the road surface he thought it would. More like black paint and stone chips. I'm not popular there with the snowblower (7.5 foot, 100hp tractor). He usually has to rake a bit off the lawn every spring. Only 2 cleans this year so far, it used to be 10 - 12 by February. And I just bought the new tractor and blower last summer! It will likely snow again in my lifetime.
  4. Feb 8, 2024 at 12:10 PM
    Tiedie
    David
    WFOY
    :worthless:
  5. Feb 8, 2024 at 3:20 PM
    Tiedie
    David
    WFOY
    Ok ok here's our sign at the bridge so you've been warned.:crazy:
    Posted this before it's kinda funny, but the truth is the Maligator can actually do it from the front porch.:rocket:
  6. Feb 8, 2024 at 4:30 PM
    w.adventures
    Nowheresville, SC
    I do need one that says beware of the dog even though I don’t have a dog. Seems like the best deterrent of them all.
    sdk1968 and six5crèéd[OP] like this.
  7. Feb 8, 2024 at 4:36 PM
    Tiedie
    David
    WFOY
    See this coming at you full speed will make you want to get back into the car.IMG_20230829_101703157.jpg
  8. Feb 9, 2024 at 6:59 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    maybe i should start a thread. but i like this one. WAY off topic but i figured the followers here wouldnt flag me right away. my fire pit. just takes 2 to 3 matches. 2 to 3 pints of gas, and a leaf blower if its raining. 20220211_181828.jpg
  9. Feb 9, 2024 at 7:16 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    read this from my email without the pic showing....
    instantly thought: wow thats a hell of a fire starter! makes more sense once you see the pix.
  10. Feb 9, 2024 at 7:17 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    for the welders of the bunch the sheet metal is corten. rusts surface only as a skin and needs no further maintaining.
  11. Feb 9, 2024 at 7:21 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    one time it didnt start well. i took my 2gal can and gave a shake. whamo!! then, when i jumped back the gas can snout it on fire! i looked up.....and locked eyes on her at the sink. she was not happy. something about a dark monkey foutain fixer i heard. probably not it. i didnt obtain injury this time. just tossed can and it went well. ish.
  12. Feb 10, 2024 at 3:43 AM
    w.adventures
    Nowheresville, SC
    After almost blowing myself up multiple times using gas… stop using gas to light your fire! Get some diesel way safer.
  13. Feb 11, 2024 at 5:48 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    This times a thousand. Gasoline vapor is super volatile and spreads out beyond where you pour. Diesel or used oil is still flammable enough to start the fire but burns slower and doesn’t have vapor that’s looking for a way to flash off.
  14. Feb 11, 2024 at 5:54 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    Since we’re throwing out ideas for safer methods. You could consider using a propane weed torch. I’ve used mine very successfully for things like this. They have more control and avoid this type of ignition.:nuclear:
  15. Feb 11, 2024 at 6:17 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    A couple of things I use are.
    Dryer lint, it's free and easy to store.
    A roll of TP. Last fall while camping at an Off Road Park I was not having any luck getting a fire started. Used a (unused) roll and worked perfectly.
    six5crèéd[OP] and sdk1968 like this.
  16. Feb 11, 2024 at 11:16 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Gas is cheaper. I like to throw a sparkler to light it from 10 feet away
  17. Feb 11, 2024 at 2:05 PM
    sdk1968
    03 Taco TRD
    i just make a trail of fuel out away from the pile & light the trail........
    but a good stump burner does the job just as good.
    six5crèéd[OP] likes this.
  18. Feb 12, 2024 at 5:37 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I saved my oil when changing it, it's great for starting fires too and I got to do something with it anyway.
    DON'T use gas, I've seen way to many people get burned from it. Like others said, it's not the liquid that burns, it's the fumes.
    308savage and sdk1968 like this.
  19. Feb 12, 2024 at 6:27 AM
    sdk1968
    03 Taco TRD
    save my oil for stump burning on the ones we dont grind out.
    thought about one of those hot oil heaters for the shop, but dont have that much oil now days.
    308savage and six5crèéd[OP] like this.
  20. Feb 12, 2024 at 12:27 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i just pour a little then stand to the side and toss matches in. i just made sure i have enough so im not adding. lesson learned:)
    sdk1968 and 308savage like this.
