Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you mow in shorts?
  1. Mow, yes, weedeat, no
    44.0%
  2. Mow and weedeat, yes
    34.0%
  3. Pants all the way for me
    22.0%
  1. Nov 22, 2020 at 3:06 PM
    #1981
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Joe and I make fire wood, one of my good buddy’s wanted a 12 for section for lumber... worked out for all of us
    six5crèéd[OP] likes this.
  2. Nov 22, 2020 at 3:07 PM
    #1982
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    12 foot section *
  3. Nov 22, 2020 at 3:27 PM
    #1983
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    Should make some coffee table cuts. Just at a lumber store yesterday, and they were selling walnut slabs about that size for 435 Cdn.
  4. Nov 22, 2020 at 4:07 PM
    #1984
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Hard to do with the saws we have I’m sure... it’ll be put to good use though. We mostly give the wood away to people who don’t have much to heat there homes with. So we keep it simple. I ask my buddy’s if they need any or have any use for it before we have at it. Some say yes some say have it ;-)
  5. Nov 26, 2020 at 6:03 AM
    #1985
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Think I’ll try and get my buddies pump tomorrow and load the tires.
  6. Nov 26, 2020 at 6:04 AM
    #1986
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Happy thanksgiving! Sounds as if you may have some work to do!
  7. Nov 27, 2020 at 9:45 AM
    #1987
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Almost done.
    shaeff, T-yoda and Bushed like this.
  8. Nov 27, 2020 at 12:06 PM
    #1988
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Was at brother joes spitting wood ... 4 hours! I’m beat
  9. Nov 27, 2020 at 5:51 PM
    #1989
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Like the deluxe seat on your 140, mine has the standard metal pan seat that someone along the way welded the springs solid :mad: -- hard on the butt...
  10. Nov 27, 2020 at 5:52 PM
    #1990
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    We have two 140’s, both have the deluxe seat :D
    I can’t imagine a hard seat, whew.
    T-yoda likes this.
  11. Nov 27, 2020 at 6:00 PM
    #1991
    RustyGreen
    sleeping in a chair
    Pavement Princess
    It is currently just a project/toy so not really a problem, I don't use it for anything but driving around the dooryard really. Sometimes I start it up just to listen to it idle, it has such a calm, relaxing sound -- so removed from the modern world.
  12. Nov 28, 2020 at 10:55 AM
    #1992
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    So here's my solution for plowing snow on the gravel and RAP.
    Definitely doesnt tear up the gravel running dry. In fact, it did a good job of smoothing it out :thumbsup:
    Now we'll just have to see how it does with the snow. Guessing it'll be fine. Don't have to get it clean, just low enough to drive on.
    shaeff, RustyGreen, Jtcmedic and 2 others like this.
  13. Nov 28, 2020 at 11:17 AM
    #1993
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    E833150F-C7A9-49D6-B5C7-7575FAEFE5E5.jpg 754EF931-FDA5-442A-BB7D-6F2134DF61A4.jpg D1A30935-1DE8-4AFE-B336-F4826F25472A.jpg 93ADE5BE-9621-4C84-A4D5-339DFB23E749.jpg More tree work this morning... all went well! Always a good time:thumbsup:
  14. Nov 28, 2020 at 11:43 AM
    #1994
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Had weighed both trucks and trailers. Joes combo was 10400 and mine was 8040. Trailers were both 2100 lbs
  15. Nov 28, 2020 at 1:07 PM
    #1995
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Went thru a logging pile and raked out the dirt and did a little grade
  16. Nov 30, 2020 at 5:27 AM
    #1996
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Yanked this old Polaris Indy 400 out of the weeds. I haven’t touched it in the five years since we had the house built. The LJ500 pulled it no problem. When the guy showed up to buy it, I lifted the track up a few inches and shoved it right up his trailer ramp. $100, not bad for about 10 minutes of “work.”
    Im trying to clean up the junk I’ve accumulated. Doing pretty well now, I think now I can probably rearrange things and end up with way more space where I park the equipment.
    Once I’m done with that, to the right in the above photo is where I put all the decent wood when we cleaned up the property. It’s been sitting a while... if nobody wants it locally, I’ll split some up for the fire pit, the rest will get dumped out back to rot away. Then I can clean up that area too.
    T-yoda, Bushed and six5crèéd[OP] like this.
  17. Nov 30, 2020 at 5:29 AM
    #1997
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    It's not junk, we refer to it as merchandise :D
    Bushed and RustyGreen like this.
  18. Nov 30, 2020 at 5:52 AM
    #1998
    shaeff
    Hudson Valley, NY
    Some of it I consider "merchandise." The stuff I'll never touch again can be removed. :) I've got all sorts of things that need to be gone through, cleaned up, organized. I really need to get my hands on a shipping container, too. I've got enough tin roofing material to put a hell of an awning on one side, that way I can park all the equipment out of the rain but still have easy access to it.
    Also need to clean some stuff out of my basement. I'm planning to allow the mini skid steer to live in there for the winter, parked on a slipsheet. That way I can finally finish up the work it needs and not worry about the damn tarp ripping off in the middle of winter.
  19. Nov 30, 2020 at 5:54 AM
    #1999
    RustyGreen
    sleeping in a chair
    Pavement Princess
    HER stuff is junk, mine is rusty collectables.
  20. Nov 30, 2020 at 6:09 AM
    #2000
    shaeff
    Hudson Valley, NY
    I need to do this, too. I was looking to buy 55gal drums of washer fluid, but honestly, I think buying it by the case like you did may be more cost effective. Everyone wants to charge freight shipping for a drum.
    A'int that the truth!
