Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Mar 1, 2020 at 4:06 PM
    #241
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I put chains on the front, may do the back as well. I back over small trees beside the creek is probably what happened to it.
  2. Mar 2, 2020 at 4:45 AM
    #242
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    That old Popper looks a little forlorn over there. Need some more pics of that!
    Just barely!
    Well if you've got it loaded right the tongue weight should only be around 350, including the trailer. And from the angle, it probably had less than that on it. :notsure:
  3. Mar 3, 2020 at 4:52 AM
    #243
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Here's a picture of half the chains when I did this on the front of the bush hog. I forget how many pieces of chain I needed but I went to the local hardware, my boss mans brother in law owns it. I told him how many pieces I needed and he said come here I'll show you how to use the cutter. He made me cut all but one :rofl:
  4. Mar 3, 2020 at 5:22 AM
    #244
    Noelie84
    Noel
    Wales, Maine
    Jesus, that's way too rich for my blood. When we built the scatter shield on my dad's brush cutter we just went down to the local tire shop and took one of their scrap tires, cut the sidewalls off, and through-bolted the tread onto the cutter :laugh:
  5. Mar 3, 2020 at 5:43 AM
    #245
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    Here’s my 1960 MF35 diesel deluxe. I use it for running round bales to the cows, snow removal, brush hogging, digging post holes, generally moving things, pulling trailers around, getting firewood, and spreading wood chips to build a few roads. It’s also great for joy rides around the hayfield with the kids. In the coming years it’s likely to start making square bales in our field once we take it over from the farmer who is haying it now
    55DF99ED-EAB3-43D2-B3D4-3B90A29CCA36.jpg 372179D8-31D2-436D-B118-ACA149CF4AAA.jpg 955F983C-15D2-46BA-86B1-6ECCEDE473ED.jpg CDFD00C3-26B9-4893-BF87-0F6360BD9E27.jpg
    Tractorman, GQ7227, shaeff and 2 others like this.
  6. Mar 3, 2020 at 8:19 AM
    #246
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Nice, wish mine was diesel. Perkins 3.152? Great little diesel! I'm rockin' the Continental z134 gasser, starts real easy (so do those Perkins'!), only run ethanol free fuel in it and haven't had any issues for the most part. I always thought that if I could find a beat up 35 with a diesel for cheap enough that I'd swap it out, but anymore that just feels like too much work for how often (or not often) I use the machine. It'd have to be the right price.
  7. Mar 3, 2020 at 8:45 AM
    #247
    Muldoon
    Robert
    Northeast Ohio
    Yep it’s the 3.152, I like it a lot. I’ve been doing what I can to give it some TLC, it wasn’t taken care of the best before I got it in 2017, it leaks here and there but nothing major. I’ve done all fluids and filters, repaired a few leaks, re-done the brakes and almost all the electrical and gauges. I’m pretty sure my generator doesn’t work anymore, looking into the alternator conversion. I also installed a block heater cause it definitely needs it to start easily once the cold weather hits. It sees a lot of rough work in brush and woods so getting it to look pretty would be a losing battle, but I’m hoping I can keep it mechanically solid for years to come.
    Only thing I wish I had was 4x4, power steering and a loader, but those are items for the next tractor I guess. Gotta save the pennies.
  8. Mar 3, 2020 at 10:47 AM
    #248
    shaeff
    Hudson Valley, NY
    For sure! I'm in the same boat as far as TLC. I bought mine non-running for $1000. Put about $7-800 into it, maybe. Need to replace a power steering line (mine's a 35 Utility, so came with heavy solid front axle, smaller rear tires ((14.9x24)) loader w/ crankshaft driven front hydraulic gear pump, two stage clutch, shuttle shift which is sweet) and I need to fix my rear main rope seal. It leaks like a sieve. If I could just stop those two leaks, my only complaint would be lack of 4x4.
    If your generator isn't working, check your ammeter. If you replaced the ammeter with a voltmeter then you need to fabricate a load (like the shunt on the back of the old ammeter) to excite the generator into charging, or just rephase the genny if it lost it's magnetic phasing.
    I'm the same way, if you saw my machine a few posts back, it looks rough and I intend to keep it that way. I've beat on it pretty darn good and it hasn't let me down yet. Painting it would be a waste, I'd get upset if it got scratched. Looking like it does, no worries!
    six5crèéd[OP] likes this.
  9. Mar 4, 2020 at 4:37 AM
    #249
    Noelie84
    Noel
    Wales, Maine
    You going to have the bores machined, or just cross your fingers and run it? They looked pretty gunky in that picture.
  10. Mar 4, 2020 at 4:51 AM
    #250
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    The 140's actually have replaceable liners in them. I've never done one so I'm interested what the outcome is with this one :popcorn:
  11. Mar 4, 2020 at 4:53 AM
    #251
    Noelie84
    Noel
    Wales, Maine
    Aha, that explains why it looked like it had been sleeved previously, then.
  12. Mar 4, 2020 at 4:57 AM
    #252
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Tractorman and Noelie84[QUOTED] like this.
  13. Mar 4, 2020 at 5:24 AM
    #253
    Muldoon
    Robert
    Northeast Ohio
    Ive read about methods to re-polarize the generator, and maybe it’s as simple a fix as that, I just haven’t gotten around to it. I try to push non-essential work to when I have warmer weather. Luckily this old tractor starts and runs and does all I need it to do as long as the wiring for the starter and battery are good haha. I’ve just put my battery on a charger a couple times now since I don’t think the generator is charging it during use. I think a modern tractor with all the electronics would drive me nuts. Heard of too many people taking their new tractors in the the dealer multiple times cause some electronic thing is keeping the thing from starting.
    Tractorman and six5crèéd[OP] like this.
  14. Mar 4, 2020 at 5:27 AM
    #254
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    The old 12V tractors with generators and external voltage regulators, if they give me any trouble I put one of these on it. Built in voltage regulator and fairly cheap. They work great for things that don't have a lot of electrical needs, like a tractor :thumbsup:
    https://www.dbelectrical.com/products/chevy-mini-alternator-denso-street-rod-race-1-wire-12180.html
  15. Mar 4, 2020 at 5:29 AM
    #255
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  16. Mar 4, 2020 at 5:34 AM
    #256
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Here's a video of a guy removing a liner that was stuck. It's an A but I think it's the same engine (C123)
    https://youtu.be/RZRqFnO8zvo
  17. Mar 4, 2020 at 8:17 AM
    #257
    Muldoon
    Robert
    Northeast Ohio
  18. Mar 4, 2020 at 5:04 PM
    #258
    Muldoon
    Robert
    Northeast Ohio
    6165E017-5829-4AF0-9862-9E3E7DEC266F.jpg One of its main tasks this winter- running hay to the cows and sheep. This winters been so mild it’s just mud mud mud. This thing needs a power washing ha
  19. Mar 4, 2020 at 6:05 PM
    #259
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    It’s the same here in NC, wet!
    Muldoon[QUOTED] likes this.
  20. Mar 4, 2020 at 6:15 PM
    #260
    shaeff
    Hudson Valley, NY
    Muldoon should be able to use that alt with ease, my tach is driven off my generator. Yesterday’stractors.com sells a Denso 10si with the tach drive already on it for $100. Not a bad deal. It’s the route I’ll eventually go.
