Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    45.5%
  2. After
    57.6%
  3. Neither
    12.1%
  4. I weed whack while someone else mows
    6.1%
Multiple votes are allowed.
  1. Feb 27, 2021 at 12:29 PM
    #2601
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    No, lol. It’s 60hp, I need an 8’ bushhog but they’re too expensive for me :D
    RustyGreen and T-yoda like this.
  2. Mar 2, 2021 at 6:34 PM
    #2602
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Got my rear chains cut today. They’ll be 1 1/2” apart. 63 pieces welded on as soon as I can find time.
    ColoradoTJ, T-yoda, Jtcmedic and 5 others like this.
  3. Mar 2, 2021 at 6:39 PM
    #2603
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Once she starts spinning’ it’s gonna match the Avatar real good too.
  4. Mar 2, 2021 at 6:41 PM
    #2604
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That is one of the best cutting bushhogs I’ve ever used. No matter how thick whatever it is you’re cutting, it leaves a clean finish. I’ve cut stuff 8’ high with it and it did amazing. It could be my width to HP ratio though, 6’ with a 60 HP tractor hooked to it :D
  5. Mar 2, 2021 at 8:19 PM
    #2605
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Gonna have to call it the Carpet Shark. The Carpet Shark's coming to take a bite out of ya'!
  6. Mar 3, 2021 at 6:04 AM
    #2606
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    Looks like a little bit of work but worth while for sure. Those chains can be a life saver - literally! I had a killer brush hog a few years ago made by Modern Manufacturing and that thing cut through anything, it was super heavy duty. Unfortunately it was stolen out of a barn that I was working at and I was never able to recover it. The cutter I replaced it with just isn't the same. It still mows through blackberries no problem but it isn't nearly as stout.
  7. Mar 3, 2021 at 1:51 PM
    #2607
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    No air or valve cores in wheel/tire, have driven around the yard, out in the street turning circles both directions using diff lock (dragging inside tire) drove around the perimeter of the yard ( wet and sloppy) tried to dig a hole with loader, wheels and tires just spun.
    If I was on a time line and had to get something done, and punctured a tire, the damn thing would be flopping off the wheel 1/4 mile from anywhere convenient to work on it.
    And I’m no light weight 6’5” and not tiny.
    they’ve only been there since 10/97 ish.....
  8. Mar 3, 2021 at 2:18 PM
    #2608
    Steve Urquell
    Bead breaking is the worst part of tire work. Hate it.
    I'm doing a little box blading today.
    PzTank, Bushed, RustyGreen and 2 others like this.
  9. Mar 3, 2021 at 4:29 PM
    #2609
    Steve Urquell
    Finished the day brush hogging my lower field. I need to get down there with my brushcutter and take care of some trees. Swisher chopped down some 2" cedar and sumac but thise 3+" oaks are beyond it. Had to do a bunch of winding and weaving.
  10. Mar 4, 2021 at 12:32 AM
    #2610
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    I got a call late Saturday afternoon that all the paperwork was in order(ish) and I could come down anytime....
    2:30 AM Sunday morning....off to Oklahoma I went. I stayed at a buddy's place and got the chance to play with some of his new toys. More on that later.
    The owner said two tires were flat spotted and would need to be changed. Well that was partially true. All five tires were smoked and looked a little octagon. Lucky I decided to bring along one spare and I purchased two wheel/tire combo's from the trailer dealership for 350.00. I installed the best octagon tire and headed back for a bumpy 664 miles Monday morning at 9:00 AM. I did 21.5 mpg on the way down doing the speed limit. On the way back...LOL! That's a heavy trailer. One wheel was balanced, two new, and my octagon. Pushed it pretty hard on the way back and did 12.2 mpg.:eek:
    On Sunday after purchasing the trailer, we went up to my friends 70 acres that he is clearing for his future builds. You can see the JD tractor in the back...
    That is a really nice tractor. 51.5 HP at 750' elevation sure does make things a lot better than 25 HP at 7550.:rofl:
    When I returned home, then the musical tires and wheels started. That's a whole other shit show story. Make sure the wheels on your trailer are rated for load. Never seen 4400 lb 16" wheels before. Even Load Trail said it was a custom order since 17.5" wheels are spec'd with 8K lb axles.
  11. Mar 4, 2021 at 6:10 AM
    #2611
    12thmanhawkfan
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    Congrats on the new trailer! Sure is nice looking.
  12. Mar 4, 2021 at 6:47 AM
    #2612
    ColoradoTJ
    Colorado
    Thank you. Hopefully it works out well.
    After using hydraulic jacks, never going back.
    FastEddy59 and six5crèéd[OP] like this.
  13. Mar 4, 2021 at 4:20 PM
    #2613
    Blkvoodoo
    Kevin
    Near Clayton NC
    there may be a slight size difference... both are 31x15.50-15 :notsure::notsure::notsure:
    six5crèéd[OP] likes this.
  14. Mar 4, 2021 at 4:21 PM
    #2614
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    When you get that other one on and aired up it’ll be the same :thumbsup:
  15. Mar 4, 2021 at 4:26 PM
    #2615
    Blkvoodoo
    Kevin
    Near Clayton NC
    I expect it’ll be close, going to tire shop in the morning, I ain’t got time or energy to mess with this, to many other things to do.
    After its mobile again full hydro fluid service and repack all 4 cyls on the loader. Clean and lube control valve
    Clean then Cut out rust in mower deck and replace with actual metal.
    then maybe I’ll be able to try and fab a grapple for the bucket.
    and all the other maint and repair I haven’t been able to accomplish the last 3 years around the crib.
  16. Mar 4, 2021 at 4:54 PM
    #2616
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Yeah, some air pressure will pop that new one right out where it belongs. I get that call all the time at work.
    "These tires you sold me are the wrong size! The numbers match, but the new ones are totally different!!"
    "Do me a favor; before you send them back, put one on the rim and air it up. Leave the tag on just in case, and call me back when you're done"
    *30-45 minutes later*
    "Yeah, we're all set"
    Most of the old timers have either died or retired, so nobody's used to how a bias ply tire will change shape under pressure anymore.
  17. Mar 4, 2021 at 7:37 PM
    #2617
    ColoradoTJ
    Colorado
  18. Mar 5, 2021 at 5:13 AM
    #2618
    Noelie84
    Noel
    Wales, Maine
    Those are nice, but a bit of a haul for me :laugh:
  19. Mar 5, 2021 at 2:01 PM
    #2619
    Blkvoodoo
    Kevin
    Near Clayton NC
    Don’t want her to go, but love watching her leave.....
  20. Mar 5, 2021 at 3:19 PM
    #2620
    Steve Urquell
    Meats!
