Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    45.5%
  2. After
    57.6%
  3. Neither
    12.1%
  4. I weed whack while someone else mows
    6.1%
Multiple votes are allowed.
  1. Mar 9, 2021 at 5:19 AM
    #2661
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Yeesh. That took some doing...
  2. Mar 9, 2021 at 2:55 PM
    #2662
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Adjusted valves .. 800 hours on this machine. Super clean
  3. Mar 9, 2021 at 4:33 PM
    #2663
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Looks brand new in there!
    Bushed, RustyGreen and T-yoda[QUOTED] like this.
  4. Mar 9, 2021 at 4:33 PM
    #2664
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Ford needs a battery, swing out tray works great until it hits the loader frame.
    07 sport 4x4, Bushed and T-yoda like this.
  5. Mar 9, 2021 at 5:04 PM
    #2665
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Like that swing out!! Something you made?
  6. Mar 9, 2021 at 5:42 PM
    #2666
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    No sir, factory.
    ColoradoTJ and RustyGreen like this.
  7. Mar 9, 2021 at 7:48 PM
    #2667
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    You find that on old forklifts and man lifts too. Works good except people keep cutting the wires back and using the crappy clamp on terminal ends until the wires are too short to allow it to swing out anymore... :smack:
    I don't mind working on stuff -- just not stuff other people have worked on.
  8. Mar 12, 2021 at 4:11 PM
    #2668
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    Weather was too nice to be inside. Little clean up of ugly things.
    Nom nom
  9. Mar 12, 2021 at 4:17 PM
    #2669
    Noelie84
    Noel
    Wales, Maine
    FTFY.
  10. Mar 12, 2021 at 5:37 PM
    #2670
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
  11. Mar 12, 2021 at 9:06 PM
    #2671
    jester156
    Cumberland, RI
    Touché.
  12. Mar 12, 2021 at 9:30 PM
    #2672
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    No sweat! I've pulled out a couple like that with my Kubota BX. Support it with the bucket, cradled between the boom and the dipper, and haul her away. Love finding rocks like that to use as features along my driveway edge or in gardens.
  13. Mar 13, 2021 at 4:20 AM
    #2673
    jester156
    Cumberland, RI
    I’ve been pulling them out along my stream all winter. Going to find something to do with them eventually.
  14. Mar 13, 2021 at 6:32 AM
    #2674
    Noelie84
    Noel
    Wales, Maine
  15. Mar 13, 2021 at 12:51 PM
    #2675
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Moved a friends Mahindra today, it’s nice.
    Rick323, Jtcmedic, ColoradoTJ and 3 others like this.
  16. Mar 13, 2021 at 4:43 PM
    #2676
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Changed 4 front mower tires today, now I remember why I was putting it off..
    Used my welding table for a tire machine, a long piece of all thread held the wheel down.
    Fortunately the old Farmall 140 came with the bead breaker attachment.
  17. Mar 13, 2021 at 4:47 PM
    #2677
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Hate doing this. I’m just glad I can take mine to the shop and use the tire machine .... even then sometimes it can fight back
  18. Mar 13, 2021 at 4:54 PM
    #2678
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Here it the project, John Deere LT 133, Kohler Command 13 hp powered, built about 1999. Seems it had the bad luck to have a tree fall on it.
    Destroyed the hood and side panels. I had an old hood from a 70's JD which is currently just sitting on there, need to make some hinges.
    Broke the blower housing, cooling tins and air cleaner - I found all of them on e-bay for about $60.
    This has a mulching deck, the blades overlap and are timed so that they don't hit. The blades turn opposite direction of each other.
  19. Mar 13, 2021 at 5:01 PM
    #2679
    Steve Urquell
    What's strange about this is I have a mag drain plug which had very little metal stuck to it. Cut open the filter and minimal glitter as well. Neither troubling.
    This era of Cub 3000s had problems with differential bolts backing out as some had no loc-tite on them from the factory. They usually grind on something but there's no significant metal in it.
    Wish I could get it out and torn down but I'm working until Tuesday.
  20. Mar 13, 2021 at 5:13 PM
    #2680
    RustyGreen
    sleeping in a chair
    Pavement Princess
    These are 6" rim front tires, the axle hole is too small to fit on the old Coats center post machine. The tires are Carlisle brand, made overseas nowadays. Even after sitting in the (very nice) sun for a few hours the sidewalls were still brutally stiff.
