Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    44.1%
  2. After
    58.8%
  3. Neither
    11.8%
  4. I weed whack while someone else mows
    5.9%
Multiple votes are allowed.
  1. Apr 25, 2021 at 1:50 PM
    #3281
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    I've seen a few white ones. One was a brick head. Possibly had blue lettering, but I maybe remembering that wrong. I'd love to add a brick head to the collection, green or white, don't really care. There was also a model built specifically for a retail chain in Canada called Canadian Tire. It had kind of a light brown or tan deck with a two stroke Lawn Boy motor with a brown shroud. Probably next to impossible to find.
  2. Apr 25, 2021 at 1:59 PM
    #3282
    Bushed
    Kenora, ON
    My memories half working. Google refreshed the other half 6afc935e1af061009038011690c220f5.jpg 4746f4126922fd5ad167cea799482d55.jpg 75977200_614.jpg
  3. Apr 25, 2021 at 2:32 PM
    #3283
    blacktacooma
    blacktacooma Well-Known Member
    Kevin
    Nova Scotia
    2001 black tacoma 4x4
    I am a cub nut. Not much into the newer ones, but don't know much about them but I do like the older international disigned ones. They are certainly well built.
    Hydrostatic transmission, power steering, hydraulic lift with front remotes.
  4. Apr 25, 2021 at 3:56 PM
    #3284
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I have a newer XT3 I mow with and 2 3000 series. They are shaft drive with expandable hydraulic circuits, hydraulic steering and deck lift, and shaft drive decks. One has a loader and hydraulic rear hitch. I pull a brush hog with the other one. Finished stripping the paint today. This is a 3205 with a liquid cooled Kawasaki and pulls the hog.
    shaeff, Bushed, T-yoda and 2 others like this.
  5. Apr 25, 2021 at 4:48 PM
    #3285
    blacktacooma
    Kevin
    Nova Scotia
    I think the 3000 series shares the same hydraulic steering and lift system with mine. I have an air cooled Magnum 20, 1010 hrs. liquid cooled would be nice!!
  6. Apr 25, 2021 at 6:33 PM
    #3286
    Steve Urquell
    Yours has 200lbs on mine as well. 3000s are 800lbs without the deck. My 3240 ballasted out with the loader on is 1500lbs.
    Here are my 3 amigos. Did some brushhogging with the tow Swisher. My lower field was up about 16" high.
  7. Apr 26, 2021 at 2:23 AM
    #3287
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
  8. Apr 26, 2021 at 5:12 AM
    #3288
    ralfnjan
    ralfnjan Well-Known Member
    I h ad a Lawnboy once. Didn't like the right front wheel placement...I always dug the front discharge into a lawn lump and the back end would lift up off the ground. Only fgractions of a second from shoving a toe into the blade a few times. I gave it to my b-i-law, he still uses it.
  9. Apr 26, 2021 at 7:29 AM
    #3289
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Finally got a few hours to put my MF back together. Was planning to split it but just have no time. It’s been sitting near my basement taken apart for months...almost a year.
    Replacing gauges on this machine is a proper sonofa B so I dragged the plasma out real quick and got busy for about 3 minutes.
    Now I have access through the battery compartment, MUCH easier!!!
    Edit: I do have a new set of gauges for it. Unfortunately, over the winter some water got into the Tach "tractormeter" and seized it, then when I hooked up the tach cable it snapped the cable. Ugh. Hoping some Kroil will free it up, new tach cable on the way. I'll install the new water temp, oil pressure, voltmeter and fuel gauge (still need a sending unit) and be all up and running.
    82789975-8141-4DCF-9F05-3FE68B4DE508.jpg D7B5DD79-22A3-4162-902C-A653E745EF28.jpg 6F1123F0-1B40-4BB5-AEC1-4BB3F2DD0BF2.jpg
  10. Apr 26, 2021 at 2:19 PM
    #3290
    Inbred
    Inbred Well-Known Member
    Phinnius
    2nd generation euphoria
    3720 First rollover. Flipped it 90 degrees on its side. Lost a quart of oil out of a breather tube as it lay. Righted it with a chain host attached to a tree 60 feet uphill. Amazing how things got haywire so dang fast. Zero damage on me or the tractor. Gotta be thankful tonight.
  11. Apr 26, 2021 at 2:26 PM
    #3291
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Glad you didn’t get hurt :cheers:
    RustyGreen, T-yoda and ColoradoTJ like this.
  12. Apr 26, 2021 at 2:29 PM
    #3292
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    :eek::eek::eek:
  13. Apr 26, 2021 at 3:51 PM
    #3293
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Sheesh! That tractor is on such a hard angle, Looks darn sketchy from the angle shown in the picture..... o_O glad nobody got hurt... live and learn :thumbsup: were you trying to pull something ? Trying to figure out what actually happened that it tipped the tractor on its side
    RustyGreen and six5crèéd[OP] like this.
  14. Apr 26, 2021 at 4:13 PM
    #3294
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Glad you're OK. Was in slo mo wasn't it?
  15. Apr 26, 2021 at 4:15 PM
    #3295
    Steve Urquell
    Man, glad you got out of it unscathed. How much ballast weight are you running on that tractor?
  16. Apr 26, 2021 at 4:18 PM
    #3296
    Inbred
    Phinnius
    Have at least 1500 hours of time on a JD 4310 with no issues. Then I bought this cab 3720 last year. So today I was clearing pricker bushes for a dual sport trainer this weekend. Went down a hill on a road I built (A down hill switch back with a hill up to my right and a drop down on my left. ) In the photo I was digging the edge of the hill to the right of my bucket just prying in hard where there was a nasty, bastard briar bush. The roots wouldn’t budge until I put full force on the bucket UP. Then the roots snapped too easily and my bucket lurched up violently. It almost caused me to flip and I did what my instincts told me to do: bury the bucket into the ground. But I had moved a few inches forward and my bucket hit the hillside flipping me like a stink bug on a spatula. It’s probably hard to understand the dynamics from how I’m describing it. Suffice to say, the beast went over and timbered like a worm wood oak tree. I had the seat belt fastened but I still whacked my head on cab glass. Then I was on my side, shutting off the engine with one thought in my head.....my wife is gonna freaking kill me. Little blood still coming out of my ear, but no other symptoms. After an hour the tractor was in my driveway, running again with no worse for the wear. Me, I had me a glass of Chalk Hill Chardonnay to calm the nerves. Thanks for the thoughts and commentary and likes/ whatnot. Can’t tell any real buddies cause they’d eviscerate me mercilessly.
  17. Apr 26, 2021 at 4:23 PM
    #3297
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    So you flipped yourself by driving the bucket down onto an incline? I can see that.
    Glad you're good :thumbsup: Bonus that the tractor's good too :D
    T-yoda, 10tacosr5, RustyGreen and 2 others like this.
  18. Apr 26, 2021 at 5:22 PM
    #3298
    10tacosr5
    10tacosr5 Well-Known Member
    Washington Twp, South NJ
    2010 Tacoma SR5 DCLB
    5100s/Headstrong Coils/Deaver AAL/Level8 MK6/FalkenWildpeakAT3
    I just gotta modify everything. Added the eBay bumper to my mower.
    T-yoda, Bushed, RustyGreen and 2 others like this.
  19. Apr 26, 2021 at 5:23 PM
    #3299
    Steve Urquell
    Good investment. You'll save breaking your hood with the bumper on.
  20. Apr 26, 2021 at 5:26 PM
    #3300
    shaeff
    Hudson Valley, NY
    Glad you’re alright, brother. Go get yourself checked out if ya start feeling off. Head injuries and whiplash are no joke.
    live and learn. Maybe think about some liquid ballast in the rear tires if you don’t haven’t already. Hills and front tractor axles get sketchy REAL fast.
    Heal quickly!
